Author Topic: A list of admins/superadmins?  (Read 4972 times)
Offline ace27
« on: February 20, 2010, 05:42:11 am »
Well, I never meant to, but I've ended up not being able to keep track of the numerous admins on my server, is there anyway to view a full list in the ulx or ulib files?
Re: A list of admins/superadmins?
« Reply #1 on: February 20, 2010, 09:11:07 am »
You can manually view normal Gmod (ULib imports it) gmod/settings/users.txt, and ULib created gmod/data/ULib/users.txt
You may also use from server console "ulx debuginfo" which will dump a file into gmod/data/ulx that has both files shown plus all the addons you use and other information.
Offline ace27
« Reply #2 on: February 20, 2010, 10:22:51 am »
Thank you, can admins be added/removed from this list (the users.txt one)?
« Reply #3 on: February 20, 2010, 11:31:30 am »
The ULib one?
Sure, as long as you know how to keep the syntax grouping.
Basically, both svn and release use the same table format
"1admin name(steamid if svn)"
"blah1"
"2admin name(steamid if svn)"
"blah2"
"3admin name(steamid if svn)"
"blah3"
You'd need to get rid of "name/steamid" and the full bracket tree { } until the next name/steamid.
"blah2"
I recommend backing up before editing. Easy to erase a wrong character and break it.
