Author Topic: physgun question  (Read 5353 times)
Offline dpoolas
physgun question
« on: April 02, 2010, 01:47:01 am »
is there a way i can make it so supers cant pick supers up and admins cant pick other admins up
just wondering
Re: physgun question
« Reply #1 on: April 02, 2010, 03:31:09 pm »
If you're asking about SVN, you're asking in the wrong section, and the question is answered in the SVN area.
If you're talking about release, you can make a player immune. This will prevent commands/physgun from being performed on them unless player trying to perform is in a higher group.
Offline dpoolas
« Reply #2 on: April 03, 2010, 01:29:23 am »
i dont know whats wrong them because i set me and my friend at the same group and same immunity and we can still physgun each others
Another question is there a way that when you physgun someone they become frozen and can't do anything
« Reply #3 on: April 03, 2010, 08:52:00 am »
I don't remember if same group members can use physgun each other or not.
As for freezing with physgun, no, but, there's always "ulx freeze"
Offline dpoolas
« Reply #4 on: April 03, 2010, 11:00:05 am »
i wonder then because i saw another server using ulx and whenver they were physgunned they were frozen and could still be moved around oh well i will look into tat
« Reply #5 on: April 04, 2010, 08:03:06 am »
Most likely a modded ULX then. If you knew how to code with lua, it wouldn't be very hard for you to modify your physgun player hook to freeze the player when picked up and to unfreeze them when let go.
