Author Topic: GMod update seems to have broken ULX  (Read 16291 times)
Offline Stevenup7002
« on: April 30, 2010, 12:52:58 pm »
Hey guys, GMod was updated today, and it seems to have broken ULX completely to the point where it won't even start. ULib appears to be working fine. Any ideas?
-Steve
Offline Chippiewill
Re: GMod update seems to have broken ULX
« Reply #1 on: April 30, 2010, 01:19:08 pm »
I appear to have a similar problem but ULIB has broken also, It may be because I am running SVN though.
« Reply #2 on: April 30, 2010, 01:21:45 pm »
*sigh*
Give us time to hack or unhack what ever Garry decided to fix or update.
« Reply #3 on: April 30, 2010, 01:24:44 pm »
Well all the other admin mods out there seem to be broken too =P. Good luck JamminR
Offline Chippiewill
« Reply #4 on: April 30, 2010, 01:28:49 pm »
Thanks Garry for another bug free update  :)
« Last Edit: April 30, 2010, 01:35:02 pm by Chippiewill »
« Reply #5 on: April 30, 2010, 01:33:35 pm »
Megiddo will be better able to comment, but I believe it to be due to the LuaJIT and the "..." vararg.
We use it extensively.
See http://www.facepunch.com/showthread.php?t=929591
Offline Chippiewill
« Reply #6 on: April 30, 2010, 01:40:46 pm »
LuaJIT is enabled by default?
Offline DiscoBiscuit
    • DiscoBuild
« Reply #7 on: April 30, 2010, 01:44:17 pm »
Yeah he put that LuaJIT and changed arg() to {...} or something like that.
THANKS GARRY
« Reply #8 on: April 30, 2010, 02:11:44 pm »
Wow, thought I got rid of all the Lua 5.0 styled code a while back, apparently not. The old style was being used in three places, code that I've carried over from project to project and haven't changed in ages... Another problem also popped up though. Garry changed the way he handles comments so I had to change some comments so they wouldn't make the parser bug out.
EDIT: Forgot to mention that we got all this squared away in ULib SVN
« Reply #9 on: April 30, 2010, 02:23:17 pm »
Did you happen to notice the new movement hooks? Perhaps you can bring Uclip back to life :D
Offline Solzay
« Reply #10 on: April 30, 2010, 02:59:21 pm »
Updated the my SVN but I'm still seeing one error in my server console.
ERROR: Hook 'ULibQueueThink' Failed: Ulib/shared/util.lua:162: bad argument #1 to 'unpack' (table expected, got nil)
Removing Hook 'ULibQueueThink'
This seems to be the only error left. Thought I'd bring it to your attention.
BTW
While I'm here posting, i thought I'd make a request. Could we get a "console spam" toggle variable that can be set to remove all the load spam from various ULib addons. I usually just comment out all the "Msg" lines, but an option to show them or not would be helpful.
« Reply #11 on: April 30, 2010, 03:07:44 pm »
I just informed Megiddo of this, there seems to be a bug with the ULib.QueueFunctionCall (which XGUI uses extensively), so, we'll hopefully be seeing a fix shortly.
Offline Chippiewill
« Reply #12 on: April 30, 2010, 03:13:31 pm »
Please post when it's fixed, not having the ability to rocket people is depressing D:
Offline Banana
« Reply #13 on: April 30, 2010, 04:00:31 pm »
Hopefully 1 admin mod will remain standing!  ASSMod has been dead for a while, so no fixes there.  gManage won't apply admin, update broke it.  ULX is the worlds last hope :o
« Reply #14 on: April 30, 2010, 04:09:37 pm »
Should be good now Banana.
@Jay, can't find anything about movement hooks changing, where did you see that?
