Author Topic: Unauthed error  (Read 8339 times)
Offline Viper
Unauthed error
« on: May 03, 2010, 04:40:02 am »
i have the same problem, exept i have full admin rights on my server and Adduser worked.... when i try !menu or ulx menu or any other command i get the same error [ULIB] Unauthed User... im running a Dedicated Server
Re: Unauthed error
« Reply #1 on: May 03, 2010, 06:07:56 am »
Any errors in console (server or client)? Did you setup sv_downloadurl appropriately?
Offline Viper
Re: Unauthed error
« Reply #2 on: May 04, 2010, 03:13:50 am »
i had the same error i mentioned spamming about 7 times everytime i tried to enter a command on the Ingame console, but the Server console is clean... as for sv_downloadurl im not entirely sure where it is, if you could give me a few pointers i would be happy :P
Re: Unauthed error
« Reply #3 on: May 04, 2010, 05:20:18 am »
So you're getting the auth error on the client?
Offline Viper
Re: Unauthed error
« Reply #4 on: May 04, 2010, 07:41:58 am »
i had the same problem with a Bought server a while ago, they installed it for me and it was the same story as here.... same error too so i dont think its the client exacly
Offline Viper
Re: Unauthed error
« Reply #5 on: May 04, 2010, 07:50:03 am »
sorry for the double post but this is the exact console error i get....
repopulating clients
Player [1][xX.V1P3R.Xx] authed superadmin
(Console) added xX.V1P3R.Xx to group superadmin
(Console) added You to group superadmin
pcmod\sh_datastream.lua:254: DataStreamClient: Unhandled stream ULibRPC!
Unknown command: NA_TypeStart
xX.V1P3R.Xx: !menu
Unknown command: NA_TypeStop
ULib/shared/sh_ucl.lua:46: [ULIB] Unauthed player
Re: Unauthed error
« Reply #6 on: May 04, 2010, 08:18:10 am »
xX.V1P3R.Xx: !menu
Is that output from a listen server, Viper? You can see that you auth correctly, but then your client isn't processing information from ULib as it needs to.
Offline Viper
Re: Unauthed error
« Reply #7 on: May 04, 2010, 08:42:26 am »
It came from the console Ingame.... im hosting on my own computer using the HL2 Dedicated Server configured for garry's mod (srcds) it has done the same thing on a server i had bought from a providor a while ago... im not sure what the problem is!
« Last Edit: May 04, 2010, 08:44:18 am by Viper »
Re: Unauthed error
« Reply #8 on: May 04, 2010, 08:55:08 am »
What is pcmod, Viper? Is that an addon? Something in wire? I just noticed the error is coming from pcmod... if you know what it is, I'd try removing it for a little while to see if that's the cause of the problem.
Offline Viper
Re: Unauthed error
« Reply #9 on: May 04, 2010, 08:59:17 am »
i dont have PCMod on the server... its a addon but i have it on my Game Client i could remove it and see if it does anything?
Offline Viper
Re: Unauthed error
« Reply #10 on: May 04, 2010, 09:44:36 am »
That Seemed to have solved it... thanks!
