Author Topic: Question  (Read 11711 times)
Offline KingSteve032
Question
« on: May 13, 2010, 07:45:03 pm »
Did the latest updates break ulx and ulib? Because I try to use it and admin stuff isn't working.
Re: Question
« Reply #1 on: May 13, 2010, 07:58:38 pm »
We've had variour reports that menu and configs aren't loading.
Most seem to correct themselves after a full 'reinstall' after removal of gmod/data/UL<*> (only in svn)
"Release" version is probably beyond repair.
Are you running SVN or release?
And, common questions... dedicated or listen? What errors, etc?
(note, I'm headed to bed soon, 16+ hours before my next response. Someone else may help)
Re: Question
« Reply #2 on: May 13, 2010, 09:18:09 pm »
I am running a dedicated server was running release but nothng was working for that so I did a reinstall with svn. Svn was still doing the same thing like release so I don't what happened.
Re: Question
« Reply #3 on: May 14, 2010, 03:13:42 pm »
Did you try moving /data/ULib and /data/ulx* and after a server restart, if you use fastdl, reupload your cache folder to your fastdl host?
Re: Question
« Reply #4 on: May 16, 2010, 08:00:18 pm »
I don't use fastdl but I i delete the data folder and reinstalled ulx and ulib nothing works still.
Re: Question
« Reply #5 on: May 16, 2010, 09:29:39 pm »
Exactly what commands are you running?
What errors are you getting when you run those commands?
Are you running them in chat or console?
Try each one.
Give results of each.
My first guess is another mod conflict, but lets see answers to above first.
Re: Question
« Reply #6 on: May 20, 2010, 01:30:48 pm »
Well i did a fresh install of my server and a fresh install of ulx/ulib and still doesnt work.
Re: Question
« Reply #7 on: May 20, 2010, 01:33:39 pm »
Well it doesn't look like I am getting any error on the server console so I don't know whats wrong.
Re: Question
« Reply #8 on: May 20, 2010, 02:15:19 pm »
Can you post the server log from the time a map starts to the time a player joins?
Re: Question
« Reply #9 on: May 20, 2010, 02:31:03 pm »
Sure let me get a screenshot of it.
Re: Question
« Reply #10 on: May 20, 2010, 02:41:15 pm »
This good? It looks like it loads correctly.
« Last Edit: May 20, 2010, 02:53:30 pm by KingSteve032 »
Re: Question
« Reply #11 on: May 20, 2010, 03:21:24 pm »
What commands are you running and what's the exact error?
Re: Question
« Reply #12 on: May 20, 2010, 04:26:50 pm »
when you say command do you mean server.cfg? And whats funny is I don't get any errors on the server console it acts like it boots up fine.
Re: Question
« Reply #13 on: May 20, 2010, 06:30:44 pm »
I mean regular ulx commands
Re: Question
« Reply #14 on: May 20, 2010, 07:32:57 pm »
No ulx commands work.
