Author Topic: Since SVN update players can move other players props  (Read 4161 times)
Offline Rambomst
« on: May 20, 2010, 02:58:18 am »
Since I updated to the latest ulib and ulx SVN players are able to move others stuff around and world objects too. I as a superadmin am not able to pick up other players and get the following error when trying to
ERROR: Hook 'ulxPlayerPickup' Failed: ulib/shared/sh_ucl.lua:44: attempt to index local 'access' (a nil value)
Removing Hook 'ulxPlayerPickup'
I have tried removing both the ulib and ulx dirs from gmod/addons and reinstalling it but that doesn't work.
*edit*
After testing some more and several restarts I have worked out that players can't move others props/doors/windows etc until an admin tries to pick up a player which will give the error
Then after an admin has caused an error everyone is able to move things they shouldn't be able to.
« Last Edit: May 20, 2010, 03:07:13 am by Rambomst »
Re: Since SVN update players can move other players props
« Reply #1 on: May 20, 2010, 05:04:07 am »
Should be fixed in ulx revision 103, thanks.
