Author Topic: I can't even start ULX  (Read 8676 times)
headshot337
« on: October 29, 2006, 11:34:59 am »
This is what I got in the console:
Game.dll loaded for "GMod 9.0.4"
GMod Folder: c:\program files\valve\steam\steamapps\sourcemods\gmod92
Processing Lua config file..
Finished Lua Config.
Creating Lua instance..
Lua Script: init/init.lua
Lua Script: init/BarrierInit.lua
Lua Script: init/portal_core.lua
Lua Script: init/propprotector.lua
Lua Script: init/swep_menu.lua
Lua Script: init/ulx_init.lua
Line 8: ULX needs ULib to run!
LUA: Errors when running script 'init/ulx_init.lua'
« Reply #1 on: October 29, 2006, 12:04:34 pm »
Did you read that? You need ULib.
« Last Edit: October 29, 2006, 12:07:25 pm by Megiddo »
headshot337
« Reply #2 on: October 29, 2006, 12:05:27 pm »
Sorry for the repeat, but if you didn't catch what was wrong, it's the bold faced part
LUA: Errors when running script 'init/ulx_init.lua' ??? ??? ???
headshot337
« Reply #3 on: October 29, 2006, 12:06:58 pm »
Yes, I have ULib
I installed everything correctly, and also read the readme.
Could you please help :(
« Reply #4 on: October 29, 2006, 12:08:33 pm »
It's not installed correctly if it's giving you that error. Make sure the ULib folder is in gmod9/lua, so you should have a file gmod9/lua/ULib/init.lua
« Reply #5 on: October 29, 2006, 12:09:09 pm »
headshot, what folder path do you have ULib in???
It _should_ be gmod9\lua\Ulib, or ULX wouldn't be giving that error.
headshot337
Re: I can't even start ULX
« Reply #6 on: October 29, 2006, 12:11:40 pm »
I have ULib in the lua folder.
« Reply #7 on: October 29, 2006, 12:12:55 pm »
Give us the full path to ULib/init.lua from the gmod9 folder.
headshot337
« Reply #8 on: October 29, 2006, 12:14:09 pm »
Ok, but the only reason why I have gmod92 is because I screwed up my
last gmod.
C:\Program Files\Valve\Steam\SteamApps\SourceMods\gmod92\lua
« Reply #9 on: October 29, 2006, 12:15:41 pm »
Please come chat with us on IRC by clicking here
headshot337
« Reply #10 on: October 29, 2006, 12:58:28 pm »
Thanks for helping!
« Reply #11 on: October 30, 2006, 03:23:32 pm »
I went on to do other things... did you get it working (or, he get it working, if someone else answers?)?
What was mixed up? Library installed in gmod2, and ULX installed in the gmod (or vice versa)?
« Reply #12 on: October 30, 2006, 03:52:59 pm »
The incorrect gmod9 folder name was messing it up.
