Author Topic: SVN download assistance request  (Read 14175 times)
Offline DoomGiver
Re: SVN download assistance request
« Reply #15 on: May 31, 2010, 04:11:20 pm »
I did double check. Triple check. and quadrupole check. unless im doing something wrong and I THINK im doing it right it's in there right. If someone could Team view me and check it out that would be nice.
Offline DoomGiver
« Reply #16 on: June 01, 2010, 02:52:44 pm »
Ok, ULX and Ulib works if i use the installer.exe one. completely works. But SVN doesn't whatsoever :(
also, here's my console from starting the game to when I started the server.
Mounting hl2.. Not Mounting hl2 (no access)
OK
Mounting ep2.. Not Mounting ep2 (no access)
No permission
Mounting tf.. OK
Mounting cstrike.. Not Mounting cstrike (no access)
No permission
Mounting dod.. Not Mounting dod (no access)
No permission
Mounting episodic.. Not Mounting episodic (no access)
No permission
Mounting hl2mp.. OK
Mounting portal.. OK
Mounting lostcoast.. Disabled
Mounting hl1.. Not Mounting hl1 (no access)
No permission
Mounting hl1mp.. Not Mounting hl1mp (no access)
No permission
Mounting zeno_clash.. Not Mounting zeno_clash (no access)
No permission
Parent cvar in server.dll not allowed (sk_apc_missile_damage)
Garry's Mod server.dll Build #081 [May 26 2010 18:45:08]
maxplayers set to 128
Steam config directory: c:\program files (x86)\steam\steamapps\doomgiver32\garrysmod\platform\config
Parent cvar in server.dll not allowed (sv_scriptenforcer_initialkick)
Didn't find particle function Rotation Orient Relative to CP
Garry's Mod client.dll Build #081 [May 26 2010 18:45:03]
maxplayers set to 1
Unknown command "sv_backspeed"
GetAllManifestFiles:  Unable to load maplist.txt
maxplayers set to 1
Unknown command "sv_rollangle"
Unknown command "sv_unlag_fixstuck"
Lua initialized (Lua 5.1)
======== Installing Table (De)Serialiser Module | ver: 1.4 ========
addons\killicons\lua\autorun\cl_killicons.lua:4: attempt to index global 'killicon' (a nil value)
//  server/upgrade.lua       //
//  shared/hook.lua          //
//  sh_base.lua              //
[ULIB] Loading SHARED module: URestrict.lua
//         URestrict         //
//Loading...                 //
//  MODULE: init.lua         //
//  MODULE: canTool.lua      //
//  MODULE: give.lua         //
//  MODULE: giveSwep.lua     //
//  MODULE: pickup.lua       //
//  MODULE: props.lua        //
//  MODULE: spawn.lua        //
//Done!                      //
[ULIB] Loading CLIENT module: URestrict_cl.lua
[ULIB] Loading CLIENT module: ur_gui.lua
===  Wire  2114 (exported)   Installed  ===
======== Beam NetVars Lib v0.71 Installed ========
EGP Lib Loading:
EGP v2 Beta Installed & Loading
Adding USM Layouts:
EGP Lib Loaded!
ERROR! Module 'zlib_b64' not found!
==== Advanced Duplicator v.1.72 shared module installed! ====
==== Advanced Duplicator v.1.85 server module installed! ====
ScriptEnforce is disabled
Loading Wire Tools
addons\kermite\lua\entities\immolate\init.lua:5: attempt to index global 'EFFECT' (a nil value)
Folder = entities/immolate
Couldn't register Scripted Entity immolate - the Type field is empty!
addons\nuke pack 4\lua\entities\mario_sent_atomic_bomb\shared.lua:6: unfinished string near '"RayFanMan(RayFan9876)'
OnRemove = function: 031F1498
TriggerInput = function: 031F1420
Folder = entities/mario_sent_atomic_bomb
SpawnFunction = function: 031F1438
Think = function: 031F1480
Initialize = function: 031F1408
PhysicsCollide = function: 031F1450
OnTakeDamage = function: 031F1468
MakeNuke = function: 03761DE0
Use = function: 031F14B0
Couldn't register Scripted Entity mario_sent_atomic_bomb - the Type field is empty!
...ddons\nuke pack 4\lua\entities\mk-82-fragile_sent_atomic_bomb\shared.lua:6: unfinished string near '"RayFanMan(RayFan9876)'
OnRemove = function: 031F18E8
TriggerInput = function: 031F1870
Folder = entities/mk-82-fragile_sent_atomic_bomb
SpawnFunction = function: 031F1888
Think = function: 031F18D0
Initialize = function: 031F1858
PhysicsCollide = function: 031F18A0
OnTakeDamage = function: 031F18B8
MakeNuke = function: 03761CA0
Use = function: 031F1900
Couldn't register Scripted Entity mk-82-fragile_sent_atomic_bomb - the Type field is empty!
Skipping E2 extension 'propcore'.
Executing listen server config file
exec: couldn't exec listenserver.cfg
Warning: using WorldTwoTextureBlend on a non-displacement surface.
Support for this will go away soon.
   - Material       : gm_construct/grass
   - Surface center : 4608 13816 0
Warning: WorldTwoTextureBlend found on a non-displacement surface (material: gm_construct/grass). This wastes perf for no benefit.
InitFastCopy: only 51% fast props. Bug?
RunConsoleCommand blocked - sent before player spawned (sv_tags)
You are running ULib version 2.40.
[ULX] Loading CLIENT module: adminmenu.lua
[ULX] Loading CLIENT module: banmenu.lua
[ULX] Loading CLIENT module: clientmenu.lua
[ULX] Loading CLIENT module: mainmenu.lua
[ULX] Loading CLIENT module: mapsmenu.lua
[ULX] Loading CLIENT module: motdmenu.lua
[ULX] Loading SHARED module: chat.lua
[ULX] Loading SHARED module: fun.lua
[ULX] Loading SHARED module: menus.lua
[ULX] Loading SHARED module: rcon.lua
[ULX] Loading SHARED module: teleport.lua
[ULX] Loading SHARED module: user.lua
[ULX] Loading SHARED module: userhelp.lua
[ULX] Loading SHARED module: util.lua
[ULX] Loading SHARED module: vote.lua
--- Missing Vgui material ignore_this_error
loading materials
loading material: cable/rope_icon
loading material: cable/cable2
loading material: cable/xbeam
loading material: cable/redlaser
loading material: cable/blue_elec
loading material: cable/physbeam
loading material: cable/hydra
loading material: arrowire/arrowire
loading material: arrowire/arrowire2
=== Loading Wire Model Packs ===
Loaded: PHXWireModels.txt
Loaded: default.txt
Loaded: expression2.txt
Loaded: bull_buttons.txt
Loaded: cheeze_buttons2.txt
Loaded: wire_model_pack_1.txt
Loaded: wire_model_pack_1plus.txt
Adding Cheeze's Buttons Pack
Adding various Buttons from HL2 and Portal
Jaanus' Thruster Pack
Beer's Model pack
EGP Lib Loading:
Adding USM Layouts:
Adding Cl Elements:
EGP Lib Loaded!
==== Advanced Duplicator v.1.741 client module installed! ====
Loading Wire Tools
--- Missing Vgui material texturemissing
AdminSpawnable = true
Spawnable = false
Spawnable = false
ERROR: Trying to derive entity sent_rg_bullet from non existant entity base_point!
ERROR: Trying to derive entity sent_nuke_radiation from non existant entity base_point!
Sending 1182 'User Info' ConVars to server (cl_spewuserinfoconvars to see)
Player [1][DoomGiver] authed
repopulating clients
populating client Player [1][DoomGiver]
RunConsoleCommand blocked - sent before player spawned (ZLib_Installed)
Player [1][unconnected] authed
AdvDupeShared: Server Compression: false
ULX version <SVN> unknown revision loaded.
Unknown command: ulx_cl_showMotd
Unknown command: ulx_cl_chattime
Unknown command: ulx_cl_welcomemessage
Unknown command: ulx_cl_logFile
Unknown command: ulx_cl_logEvents
Unknown command: ulx_cl_logChat
Unknown command: ulx_cl_logSpawns
Unknown command: ulx_cl_logSpawnsEcho
Unknown command: ulx_cl_logDir
Unknown command: ulx_cl_logEcho
Unknown command: ulx_cl_rslotsMode
Unknown command: ulx_cl_rslotsVisible
Unknown command: ulx_cl_votemapEnabled
Unknown command: ulx_cl_votemapMintime
Unknown command: ulx_cl_votemapWaittime
Unknown command: ulx_cl_votemapSuccessratio
Unknown command: ulx_cl_votemapMinvotes
Unknown command: ulx_cl_votemapVetotime
Unknown command: ulx_cl_votemapMapmode
Unknown command: ulx_cl_voteEcho
Unknown command: ulx_cl_votemap2Successratio
Unknown command: ulx_cl_votemap2Minvotes
Unknown command: ulx_cl_votekickSuccessratio
Unknown command: ulx_cl_votekickMinvotes
Unknown command: ulx_cl_votebanSuccessratio
Unknown command: ulx_cl_votebanMinvotes
===  Wire revision: 0     ===
=== Local Wire revision:0 ===
Redownloading all lightmaps
Hope it helps, I really wanna get the SVN to work so I can use URestrict :(
