Author Topic: Gatekeeper Support  (Read 6480 times)
Offline lavacano201014
Gatekeeper Support
« on: June 05, 2010, 01:20:08 pm »
I don't know how feasible this is in Lua (meaning I don't know if Lua has anything similar to a try-except in Python), but here goes anyway.
I'd like to have in ULX the ability to use Gatekeeper (if it's installed). The simple way to do this try to load gatekeeper at the beginning of ULX initialization, and if it throws an error to the effect of "IT'S NOT THERE Q.Q" then revert to using kickid and banid (as ULX uses now).
Then the kick function would have something to the effect of:
if gatekeeper then
   gatekeeper.Drop(userid, kick_message)
   -- Current ULX kick code here
And ban would just record the ban and call the kick function.
I'm sure a lot of people think the Kicked By Console : Reason Here thing is kind of sloppy, and while 99% of them know it's not your fault, it would still look better from an aesthetic point of view.
I could do it myself (without the check, because I would know gatekeeper's there), but I'm lazy D-:
Re: Gatekeeper Support
« Reply #1 on: June 05, 2010, 02:03:47 pm »
How many servers use or have gatekeeper installed?
Offline DiscoBiscuit
    • DiscoBuild
« Reply #2 on: June 05, 2010, 04:06:44 pm »
Meee
« Reply #3 on: June 06, 2010, 09:17:40 am »
Added support for gatekeeper as requested in rev 146. (Woo 3 lines of code)
