Author Topic: setgroupcantarget  (Read 10042 times)
setgroupcantarget
« on: June 09, 2010, 03:31:57 pm »
This doesn't have anything to do with cfg, but how does the "ulx setgroupcantarget" command work?  As in how does it set it, I have been playing around with it and don't quite understand it.  If I do "ulx setgroupcantarget admin !%superadmin" they would end being able to target everyone unless this isn't finished yet.
Re: setgroupcantarget
« Reply #1 on: June 09, 2010, 04:05:55 pm »
That command with those parameters, if used, would make it so admins can target everyone except superadmins or other groups that inherit from superadmin (which happens to be the default setup now).
Does that help?
« Reply #2 on: June 09, 2010, 08:38:58 pm »
Not really, when I try it admins are able to kick/ban/slap/ect. ect. anyone.  The only way it works is if I put it directly in the command.
« Reply #3 on: June 10, 2010, 05:21:20 am »
Admins can kick/ban/slap even superadmins? Use a debug dump and paste it here.
« Last Edit: June 10, 2010, 09:56:53 pm by Megiddo »
« Reply #4 on: June 10, 2010, 09:00:21 pm »
Let me try a few things then if it still isn't working right I'll debug it for you.
