Author Topic: ULX dosent start up  (Read 11009 times)
Offline kennis942
ULX dosent start up
« on: June 11, 2010, 11:14:32 am »
Hello, in a few days now my ULX wouldnt start up, i do not know why it dosent work but i need help i have tryed reinstalling it numerous times..
When i go on my server this is the console output:
Network: IP 77.19.58.66, mode MP, dedicated No, ports 27015 SV / 27005 CL
Connecting to 94.23.229.40:27022...
Connected to 94.23.229.40:27022
sandbox
Map: gm_construct
Players: 1 / 12
Build: 3943
Server Number: 1
No pure server whitelist. sv_pure = 0
Not deleting directory cache/dua/ (directory is locked)
Decompressing data pack into virtual file system..
Data pack loaded: 1612 files. (14.749s)
Lua initialized (Lua 5.1)
Not on server
EGP Lib Loading:
EGP v2 Beta Installed & Loading
Adding USM Layouts:
Adding Cl Elements:
EGP Lib Loaded!
======== Installing Table (De)Serialiser Module | ver: 1.4 ========
StarGate Pack: Initializing
Version: 46
Loading: stargate/shared/init.lua
Loading: stargate/shared/bullets.lua
Loading: stargate/shared/lib.lua
Loading: stargate/shared/matrix.lua
Loading: stargate/shared/print_r.lua
Loading: stargate/shared/tracelines.lua
Loading: stargate/client/init.lua
Loading: stargate/client/menu.lua
Loading: stargate/client/modelclipping.lua
Loading: stargate/vgui/saddresspanel.lua
Loading: stargate/vgui/saddressselect.lua
Loading: stargate/vgui/scontrolepanel.lua
Loading: stargate/vgui/shelpbutton.lua
Loading: stargate/vgui/shtmlhelp.lua
RunConsoleCommand blocked - sent before player spawned (ulib_cl_loaded)
wire\UpdateCheck.lua:12: attempt to index a nil value
======== Beam NetVars Lib v0.71 Installed ========
--- Missing Vgui material ignore_this_error
loading materials
loading material: cable/rope_icon
loading material: cable/cable2
loading material: cable/xbeam
loading material: cable/redlaser
loading material: cable/blue_elec
loading material: cable/physbeam
loading material: cable/hydra
loading material: arrowire/arrowire
loading material: arrowire/arrowire2
=== Loading Wire Model Packs ===
Loaded: PHXWireModels.txt
Loaded: Spacebuild Model Pack.txt
Loaded: Stargate.txt
Loaded: default.txt
Loaded: expression2.txt
Loaded: bull_buttons.txt
Loaded: cheeze_buttons2.txt
Loaded: wire_model_pack_1.txt
Loaded: wire_model_pack_1plus.txt
Adding Cheeze's Buttons Pack
Adding various Buttons from HL2 and Portal
Jaanus' Thruster Pack
Beer's Model pack
RunConsoleCommand blocked - sent before player spawned (sv_tags)
===== PointMod by Seth Loaded =====
Running file: base.lua
Running file: hud.lua
Running file: menu.lua
Running file: items.lua
No instance of the Planetfall Data Record System has been detected, initializing.
No instance of the Planetfall Trace Bullet Library has been detected, initializing.
No instance of the Planetfall Usermessage Extensions Module has been detected, initializing.
Warning: vgui.Create failed to create the VGUI component (ControlPanel)
Trace:
1: Line 32 "Trace" lua\includes\extensions\debug.lua
2: Line 26 "(null)" lua\includes\modules\controlpanel.lua
3: Line -1 "" (tail call)
4: Line 186 "initControls" addons\ucctv\lua\autorun\cctv.lua
5: Line 229 "(null)" addons\ucctv\lua\autorun\cctv.lua
lua\includes\modules\controlpanel.lua:27: controlpanel.Get() - Error creating a ControlPanel!
You're calling this function too early! Call it in a hook!
ERROR! Module 'zlib_b64' not found!
==== Advanced Duplicator v.1.72 shared module installed! ====
==== Advanced Duplicator v.1.741 client module installed! ====
-english-
Loading: cl_tab.lua...Loaded: Successfully
Loading: module_loader.lua...Loaded: Successfully
Loading: defaults.lua...Sent: Successfully
Loading: lifesupport.lua...Loaded: Successfully
Loading: lifesupport1.lua...Loaded: Successfully
Loading: lifesupport2.lua...Loaded: Successfully
Loading: lsents.lua...Loaded: Successfully
Loading: miningaddon.lua...Loaded: Successfully
Loading: petrolsystemsents.lua...Loaded: Successfully
Loading: resdistrib1.lua...Loaded: Successfully
Loading: resdistrib2.lua...Loaded: Successfully
Loading: resourcedistribution.lua...Loaded: Successfully
Loading: resourcetransit.lua...Loaded: Successfully
Loading: sbep.lua...Loaded: Successfully
Loading: spacebuild.lua...Loaded: Successfully
ERROR! Module 'chrome' not found!
addons\sbmp\lua\autorun\client\joystickreorder.lua:5: attempt to index local 'a' (a nil value)
Loading CAF Tools
loading stool: ls3_energysystems.lua
sbox_maxls3_energysystems -> 30
CAF Tool: Loading device defs
Loading dev type: extra_co2_gens
Loading dev type: extra_fusion_gens
Loading dev type: extra_h_gens
Loading dev type: extra_ln_gens
Loading dev type: extra_n_gens
Loading dev type: extra_o2_gens
Loading dev type: extra_solar_panels
Loading dev type: extra_water_air_extractors
Loading dev type: extra_water_heaters
Loading dev type: extra_water_pumps
Loading dev type: sbep_extra_fusion_generators
loading stool: ls3_environmental_control.lua
sbox_maxls3_environmental_control -> 30
Loading dev type: sbep_extra_climate_control
loading stool: ls3_other.lua
sbox_maxls3_other -> 30
Loading dev type: extra_ls_screens
loading stool: ls3_other_lights.lua
sbox_maxls3_other_lights -> 10
loading stool: ls3_receptacles.lua
sbox_maxls3_receptacles -> 20
Loading dev type: extra_co2_storage
Loading dev type: extra_energy_storage
Loading dev type: extra_heavy_water_storage
Loading dev type: extra_h_storage
Loading dev type: extra_ln_storage
Loading dev type: extra_n_storage
Loading dev type: extra_o2_storage
Loading dev type: extra_steam_storage
Loading dev type: extra_water_storage
loading stool: miningaddon.lua
CAF\Stools\miningaddon.lua:17: attempt to index global 'RD2ToolSetup' (a nil value)
sbox_maxmining -> 10
loading stool: petroldev.lua
CAF\Stools\petroldev.lua:19: attempt to index global 'RD2ToolSetup' (a nil value)
sbox_maxrddevices -> 30
loading stool: petrolgen.lua
CAF\Stools\petrolgen.lua:19: attempt to index global 'RD2ToolSetup' (a nil value)
sbox_maxrdgenerators -> 30
loading stool: petrolstor.lua
CAF\Stools\petrolstor.lua:19: attempt to index global 'RD2ToolSetup' (a nil value)
sbox_maxrdstorage -> 30
loading stool: petrol_wheel.lua
loading stool: pumps.lua
sbox_maxpumps -> 10
loading stool: resourcenodes.lua
sbox_maxresourcenodes -> 30
loading stool: sbep_res_mods.lua
sbox_maxsbep_res_mods -> 30
Loading dev type: base_res_module
loading stool: sb_dev_plants.lua
sbox_maxsb_dev_plants -> 30
loading stool: sb_terraformer.lua
sbox_maxsb_teraformers -> 30
loading stool: valves.lua
sbox_maxvalves -> 10
loading stool: sbep_hab_mods.lua
Loading Wire Tools
--- Missing Vgui material texturemissing
Can't find factory for entity: info_null
addons\nuke pack 4\lua\entities\mario_sent_atomic_bomb\shared.lua:6: unfinished string near '"RayFanMan(RayFan9876)'
Folder = entities/mario_sent_atomic_bomb
AdminSpawnable = true
Spawnable = false
Couldn't register Scripted Entity mario_sent_atomic_bomb - the Type field is empty!
...ddons\nuke pack 4\lua\entities\mk-82-fragile_sent_atomic_bomb\shared.lua:6: unfinished string near '"RayFanMan(RayFan9876)'
Folder = entities/mk-82-fragile_sent_atomic_bomb
Spawnable = false
Couldn't register Scripted Entity mk-82-fragile_sent_atomic_bomb - the Type field is empty!
test
test
RunConsoleCommand blocked - sent before player spawned (lw_hud_exec_build)
KeyValues Error: RecursiveLoadFromBuffer:  got EOF instead of keyname in file settings/spawnlist/[organicbridge]cockpits, medium.txt
SpawnMenu, (*Entries*),
KeyValues Error: RecursiveLoadFromBuffer:  got EOF instead of keyname in file settings/spawnlist/[organicbridge]engines, medium.txt
KeyValues Error: RecursiveLoadFromBuffer:  got EOF instead of keyname in file settings/spawnlist/[organicbridge]external corridors, medium.txt
KeyValues Error: RecursiveLoadFromBuffer:  got EOF instead of keyname in file settings/spawnlist/[organicbridge]extras.txt
ERROR: Trying to derive entity base_weapons_module from non existant entity base_rd_entity!
ERROR: Trying to derive entity sent_nuke_radiation from non existant entity base_point!
ERROR: Trying to derive entity dakara_wave from non existant entity base_point!
ERROR: Trying to derive entity railgun from non existant entity base_rd_entity!
ERROR: Trying to derive entity gate_nuke_rings from non existant entity base_point!
Sending 1642 'User Info' ConVars to server (cl_spewuserinfoconvars to see)
[UCL] Access set.
[UTime]Welcome back ({SM})^2M^3i^5l^1o, you last played on this server 06/11/10 00:52:11
This server is using the Custom Addon Framework
Report any bugs during the beta on http://www.snakesvx.net
Welcome to ({SM}) SpaceBuild Server | FastDL [Stargate,Jumper,PlayerX,WireSVN,WireUSVN]! We're playing gm_construct.
PlayX DEBUG: JW URL set
PlayX DEBUG: Host URL set
Warning: Unhandled usermessage 'ulib_sound'
This server is running ULib version 2.21.
[ULIB] Loading SHARED module: aafk.lua
[ULIB] Loading SHARED module: urestrict.lua
ULib\modules\urestrict.lua:267: attempt to index field 'cmds' (a nil value)
[ULIB] Loading CLIENT module: urestrict_cl.lua
[ULIB] Loading CLIENT module: ur_gui.lua
RunConsoleCommand blocked - sent before player spawned (ulib_cl_ulib_loaded)
AdvDupeShared: Server Compression: false
Addon: Spacebuild Enhancement Pack got enabled
Warning: Unhandled usermessage 'wire_rev'
RunConsoleCommand blocked - sent before player spawned (ZLib_Installed)
Redownloading all lightmaps
CAF: Client has Internet. Enabled Online-Help
An error occured when trying to enable Addon: Mining Addon
Addon: Life Support Entities got enabled
Addon: Life Support got enabled
Addon: PetrolSystem Entities got enabled
PlayX DEBUG: Providers list received
Addon: Resource Distribution got enabled
Warning: Unhandled usermessage 'ulx_resetinfo'
Warning: Unhandled usermessage 'ulx_autocomplete'
Warning: Unhandled usermessage 'ULXMotdStart'
Warning: Unhandled usermessage 'ULXMotdText'
Warning: Unhandled usermessage 'ULXMotdEnd'
Warning: Unhandled usermessage 'SendMotdMenu'
Warning: Unhandled usermessage 'UpdateTimeLeft'
You're playing on ({SM}) SpaceBuild Server | FastDL [Stargate,Jumper,PlayerX,WireSVN,WireUSVN], enjoy your stay!
({SM})^2M^3i^5l^1o is now afk
Syntax: setinfo <key> <value>
This server is running ULX Admin Mod version 3.31 by Team Ulysses -- ulyssesmod.net
Still AFK, However kick has been disabled.
({SM})^2M^3i^5l^1o is now back from being AFK
I have This in Addons:
Adv Duplicator 24/03/2010 23:27:26
  Advanced Gyropod 13/04/2010 23:22:15
  Anti-NoClip 25/03/2010 19:27:04
  AntiAFK 01/04/2010 20:51:36
  Asuran_weapon 18/05/2010 06:27:53
  CAF 03/06/2010 16:04:53
  catdaemon_stargate 24/03/2010 23:25:57
  Conna's Tools Pack 25/03/2010 19:23:50
  counter-strike 27/05/2010 18:16:19
  daf 24/03/2010 19:16:14
  day-of-defeat 27/05/2010 18:16:19
  default_sent_pack 27/05/2010 18:16:19
  derma 27/05/2010 18:16:19
  Dev 09/06/2010 04:02:23
  DoorSTool 28/03/2010 10:05:27
  Fin2 31/03/2010 02:17:20
  gmdm_resources 24/03/2010 23:29:07
  hl2_ep2 27/05/2010 18:16:19
  Jumper 2.5 03/03/2010 17:46:51
  LS3C 03/06/2010 16:06:03
  LS3E 03/06/2010 16:21:07
  maps 06/04/2010 22:59:07
  materials 06/04/2010 22:22:04
  Mining Addon 09/06/2010 04:01:37
  MW2 name colors 25/04/2010 16:30:06
  No Collide Multi 29/03/2010 06:47:58
  No collide world 29/03/2010 06:47:47
  ParentbyNano 17/05/2010 05:43:20
  Petrol Systems 09/06/2010 04:01:37
  PewPew 25/04/2010 16:08:41
  phx3 04/04/2010 19:52:26
  PlayerTitle 03/04/2010 00:12:12
  PlayX 02/05/2010 15:39:10
  portal 27/05/2010 18:16:19
  prop_shield 22/04/2010 04:41:13
  RD3 03/06/2010 16:46:22
  Rep Rev26 Patch 05/06/2010 06:59:12
  Resource Burner 25/04/2010 16:19:56
  Resource Distribution 09/06/2010 04:01:53
  Resource Transit System 09/06/2010 04:01:54
  SB3 06/06/2010 17:40:09
  SBEP 09/06/2010 23:06:52
  SBEP_Models 09/06/2010 23:05:27
  SGweapons 09/06/2010 22:40:25
  Smart_Constraint 25/03/2010 22:58:23
  smart_welding 25/03/2010 19:21:38
  Spacebuild 09/06/2010 04:02:05
  Stacker STool 16/05/2010 00:28:04
  stargate 24/03/2010 23:29:07
  Stargate Extras 06/05/2010 22:36:14
  stargate gdo 25/03/2010 22:35:07
  stargate_resources 25/03/2010 07:40:33
  sui_scoreboard_modified_v2 25/03/2010 14:43:51
  temp snippets 09/06/2010 04:02:05
  tf2 27/05/2010 18:16:19
  Tiberium Addon 08/06/2010 22:24:29
  UantiPhysgun 28/03/2010 14:41:53
  ulib 11/06/2010 19:47:41
  ulx 11/06/2010 19:47:41
  ULX_OldSchoolImmunity 06/04/2010 23:01:21
  UnoLimited 24/03/2010 23:41:04
  Urestrict 24/03/2010 20:47:13
  UTime 25/03/2010 14:29:37
  WeightSTool 25/03/2010 22:32:57
  wiki generations files 09/06/2010 04:02:05
  wire 28/03/2010 11:38:50
  wire model pack 1 28/03/2010 11:40:17
  wirextras 24/03/2010 22:12:48
  zeno_clash 27/05/2010 18:16:19
  CREDITS-Put your name in here + what you are working on.txt 918 Bytes TXT 09/06/2010 04:02:05
  dosattackfix.vdf 80 Bytes VDF 13/04/2010 23:15:48
  License gpl-3.0-standalone.htm 36,23 KB HTM 09/06/2010 04:02:05
I run a dedicated server and i have made sevral entity edits to depend on ULX, and i need help FAST.
If theres any more information i could provide, tell me how to output it.
i would go as far as giving you FTP acces to my server ....
IP:94.23.229.40:27022
Re: ULX dosent start up
« Reply #1 on: June 11, 2010, 12:54:31 pm »
You're using the release version of ULX? Garry's broken about a dozen things that the release version relied on in order to function, so I'd recommend using ULX and ULib SVN until the next release (which should be soon!). We don't normally recommend ULX and ULib SVN, but since we're so close to the next release you should be fine using it.
Offline kennis942
« Reply #2 on: June 11, 2010, 01:21:55 pm »
ofc im using the SVN the 81 patch broke all addons using datastream... but the last few days it hasent started properly, after a few restart it would start, then noy the last 2 days it would not start at all.
« Reply #3 on: June 11, 2010, 01:44:37 pm »
Garry broke datastream, but he fixed it now. According to your console, the server is running ULX v3.31, a really, really old version. :)
Offline kennis942
« Reply #4 on: June 11, 2010, 02:44:38 pm »
i have re downloaded and installed  the SVN version of both and its still not works.
Console output:
Unable to read pack file: cache/8c73b8b98804d88e50a384a40d457dc9.dua
Unable to load virtual file system!
Not on server
Version: 46
Loading: stargate/vgui/SAddressPanel.lua
Loading: stargate/vgui/SAddressSelect.lua
Loading: stargate/vgui/SControlePanel.lua
Loading: stargate/vgui/SHelpButton.lua
Loading: stargate/vgui/SHTMLHelp.lua
Trace:
EGP Lib Loading:
EGP Installed & Loading
--- Missing Vgui material EGP->Ignore
EGP Loading USM Layouts
EGP Loading Elements
--Added: circle
--Added: boxangle
--Added: E
--Added: text
--Added: box
--Added: line
--Added: poly
--Added: boxoutline
--Added: text1
--Added: triangle
Adding USM Layouts:
Adding Cl Elements:
EGP Lib Loaded!
addons\wire\lua\wire\updatecheck.lua:12: attempt to index a nil value
loading materials
Loaded: default.txt
Beer's Model pack
-english-
Loading: Module_Loader.lua...Loaded: Successfully
Loading: Defaults.lua...Sent: Successfully
Loading: LifeSupport.lua...Loaded: Successfully
Loading: LIFESUPPORT1.lua...Loaded: Successfully
Loading: LIFESUPPORT2.lua...Loaded: Successfully
Loading: LSEnts.lua...Loaded: Successfully
Loading: ResDistrib1.lua...Loaded: Successfully
Loading: ResDistrib2.lua...Loaded: Successfully
Loading: ResourceDistribution.lua...Loaded: Successfully
Loading: ResourceTransit.lua...Loaded: Successfully
Loading CAF Tools
Loading dev type: extra_CO2_gens
Loading dev type: extra_H_gens
Loading dev type: extra_LN_gens
Loading dev type: extra_N_gens
Loading dev type: extra_O2_gens
Loading dev type: extra_CO2_storage
Loading dev type: extra_H_storage
Loading dev type: extra_LN_storage
Loading dev type: extra_N_storage
Loading dev type: extra_O2_storage
sbox_maxpumps -> 10
...swn\lua\weapons\gmod_tool\stools\wire_touchplate.lua:1: attempt to index global 'WireToolSetup' (a nil value)
Loading Wire Tools
Spawnable = false
Spawnable = false
--Added: circle
--Added: boxangle
--Added: E
--Added: text
--Added: box
--Added: line
--Added: poly
--Added: boxoutline
--Added: text1
--Added: triangle
test
test
Sending 1507 'User Info' ConVars to server (cl_spewuserinfoconvars to see)
[UTime]Welcome back ({SM})^2M^3i^5l^1o, you last played on this server 06/11/10 23:23:57
Warning: Unhandled usermessage 'PlayXHostURL'
Warning: Unhandled usermessage 'ulx_initplayer'
Warning: Unhandled usermessage 'ulx_addMenuItem'
DataStreamClient: Unhandled stream ULibRPC!DataStreamClient: Unhandled stream ULibRPC!DataStreamClient: Unhandled stream PlayXProvidersList!RunConsoleCommand blocked - sent before player spawned (ZLib_Installed)
DataStreamClient: Unhandled stream ULibRPC!DataStreamClient: Unhandled stream ULibRPC!DataStreamClient: Unhandled stream ULibRPC!DataStreamClient: Unhandled stream ULibRPC!DataStreamClient: Unhandled stream ULibRPC!Couldn't include file 'entities\gmod_wire_expression2\core\custom\cl_stargate.lua' (File not found)
Warning: Unhandled usermessage 'ulib_repWriteCvar'
DataStreamClient: Unhandled stream ULibRPC!Player Lordoflard has joined the game
Player Lordoflard left the game (Disconnect by user.)
DataStreamClient: Unhandled stream ULibRPC!DataStreamClient: Unhandled stream ULibRPC!Error! Variable "$reflectentities" is multiply defined in material "spacebuild/glass"!
DataStreamClient: Unhandled stream ULibRPC!This server is running ULX Admin Mod version <SVN> unknown revision by Team Ulysses -- ulyssesmod.net
Lordoflard<STEAM_0:0:31110900> spawned sent asgard_beam
Lordoflard<STEAM_0:0:31110900> spawned sent destiny_turret
Lordoflard<STEAM_0:0:31110900> spawned sent stationary_railgun
Failed to load sound "railgun\move.wav", file probably missing from disk/repository
Player Lordoflard left the game (Lordoflard timed out)
DataStreamClient: Unhandled stream ULibRPC!DataStreamClient: Unhandled stream ULibRPC!You're playing on ({SM}) SpaceBuild Server | FastDL [Stargate,Jumper,PlayerX,WireSVN,WireUSVN], enjoy your stay!
« Last Edit: June 11, 2010, 03:28:19 pm by kennis942 »
« Reply #5 on: June 11, 2010, 03:54:48 pm »
Now your problem is that you don't have sv_downloadurl setup correct and/or the cache isn't generating properly (see errors in the first four lines? those are very bad if they're saying what I think they are).
Offline kennis942
« Reply #6 on: June 11, 2010, 04:16:39 pm »
//Downloads
sv_allowupload 0
sv_allowdownload 0
sv_downloadurl "http://94.23.229.40/94.23.229.40-27022"
i assure you its rigth set up my provider said so, mty server came pre configured exactly like that. ill try to update the cache but it will take some time ...i have tryed updating the thing SEVRAL times before so yeah dont see where it could help maybne it corrupt or something..
Offline kennis942
« Reply #7 on: June 11, 2010, 05:00:33 pm »
DataStreamClient: Unhandled stream ULibRPC!DataStreamClient: Unhandled stream ULibRPC!DataStreamClient: Unhandled stream PlayXProvidersList!DataStreamClient: Unhandled stream ULibRPC!DataStreamClient: Unhandled stream ULibRPC!DataStreamClient: Unhandled stream ULibRPC!DataStreamClient: Unhandled stream ULibRPC!DataStreamClient: Unhandled stream ULibRPC!Couldn't include file 'entities\gmod_wire_expression2\core\custom\cl_stargate.lua' (File not found)
i  saw a glimt of datastream error ...
it says now , something is broken with the datastream how do i fix ? can i delete the files and updatemy server , will that fix it ?
« Reply #8 on: June 11, 2010, 05:03:14 pm »
Your sv_downloadurl comes up with "website cannot be found". The clients aren't downloading the files they need.
Offline kennis942
« Reply #9 on: June 11, 2010, 05:48:06 pm »
i know, i asked the administrator about this but he said it would work...but i will issue him now i remeber i did this before but i cant seam to find the entry
« Reply #10 on: June 15, 2010, 09:16:59 am »
mmmm I was just able to open your sv_downloadurl and it was in french.  So it isn't your downloadurl unless it just fixed between our posts.
EDIT:  and wow... you have a ton of addons :P
« Reply #11 on: June 15, 2010, 09:21:26 am »
It has been four days, i'm guessing he fixed it.
« Reply #12 on: June 15, 2010, 09:22:19 am »
 :-[  sorry didn't notice the date
