Author Topic: How come when i changed map, it revoked my admin.  (Read 3918 times)
Offline FuryBlitz
« on: June 22, 2010, 10:22:23 am »
I wanted to change my map to gm_construct, so i did. Then when i tried to do a ulx command, it said "you do not have access to this command" I restarted my server, and it still wouldnt let me do anything. I rejoined, still couldn't do anything. I used the rcon ulx adduser but it still said i had no access. What do i do. I also went into the users.txt in settings and data.
Re: How come when i changed map, it revoked my admin.
« Reply #1 on: June 22, 2010, 10:28:55 am »
Did you accidentally set your data files to readonly?
Offline FuryBlitz
« Reply #2 on: June 22, 2010, 10:41:30 am »
No. I was just on the server, and there were a lot of errors because of spammers, so i changed the map, and when i got on, i wasnt admin anymore.
Offline FuryBlitz
« Reply #3 on: June 22, 2010, 10:56:17 am »
Never mind i got it working. All i had to do is rename the groups.txt and misc_registered.txt and restarted server.
