Author Topic: Adding a admin??  (Read 3933 times)
Offline Cookie Monster
Adding a admin??
« on: June 22, 2010, 12:09:59 pm »
Hello.. iam getting pretty angry now... i have ordered A Server on LowPings.net..
there i can choose addons... i pressed the ULX and installed it to the server.
But what now???
When i go ingame at the server (garrysmod), and try to write forexample "@@@ Hello@ or "!adminmenu! is this following text popping up ALSO in console "you dont have access to this command... how do i get it to work?
PLS send Step by Step ;)
Re: Adding a admin??
« Reply #1 on: June 22, 2010, 12:46:41 pm »
The FAQ section under help and support is exactly what you're looking for.
« Reply #2 on: June 22, 2010, 04:41:34 pm »
Cookie Monster, Though our FAQ area of the forums give step by step for many typical ULX items, no matter what addon you use, I recommend reading all of this - http://wiki.garrysmod.com/?title=Admin
ULX imports from the file it gives instructions for adding yourself as a superadmin to.
Every addon written for Gmod that uses 'admin' access to base itself on worth it's weight in gold uses the same file.
That site also gives many other server tips for limits/etc.
