Author Topic: Serious Builders' Server!  (Read 3761 times)
Offline CDBettler
« on: June 23, 2010, 08:25:02 pm »
Launched many times before, the Serious Builders' Server is up and here to stay. Running off of a hardwired connection, on a gaming PC.
The specs are as follows:
Q8200 Quad @2.33GHz
9600GSO
4GB PNY DDR2 RAM
500GB Storage
IP- 24.102.250.101:27015
Maxfps-600
TickRate-100
MaxRate-16640
Addons:
[SVN]
PHX
Wire
Propeller Model Pack
Chris's Vehicle Pack
ULX&ULib
Wire Model Pack 1
Burak575's Piston Tool & Model Pack
[Non-SVN]
Amraam
Buoyancy Tool
UPS
Bodygroup_Stool
Easy Precision .95a
Earthquake
OL_Stacker
Smart_Constraint
SmartSnap
WeightSTool
Wheels Pack
Wire Facer
Fin 2
G-Hadi G-Man
Anti-NoClip
VU Mod 2.6
Laser STool 2
Nuke Pack 4
Parachute & Deployer
Player Weld
Explosive Entities
TNT
Unbreakable STool
We aren't strictly Building, that's just what we do most of the time. If you want to come in and minge, don't because you will be kicked. But if you want to build, show off, or learn something, join up!
Bettler
[TEC]MrWhite
Dr. Love
|xBlindFirex|
Pvt. B
Fear2aim
Re: Serious Builders' Server!
« Reply #1 on: June 23, 2010, 09:06:38 pm »
I noticed it's on your home connection. What type of connection do you have?
Offline CDBettler
« Reply #2 on: June 24, 2010, 12:39:01 pm »
It's a cable modem, i'm wired directly into it. .78MB/s UP and 4.8MB/s DOWN. If i could get any better out here, i would XD.
« Reply #3 on: June 24, 2010, 03:14:15 pm »
CDBettler, Unless you're setting your max players to 3, you're going to have some unhappy laggers due to your limited upload.
(And unhappy parents/roommates/yourself if you try to surf using another machine.)
I keep the following in my server.cfg file for any Source servers I use. It works quite well.
// TIP for setting your rates. This tip is coming from a thread in www.steampowered.com forum. We can't guarantee if it really works.
// In case of LAG issue you can change the following lines.
// Maximum amount of bandwidth clients can use (0=unlimited, max=20000)
// Formula : sv_maxrate = bandwidth X 125 / number_of_slots
//   Example :
//     Assumptions :
//     . upload bandwidth = 768 kbps and download = 10mbps. Take the lowest value (768).
//     . slots = 10
//     So : sv_maxrate = 768 * 125 / 10 = 9600
// Minimum amount of bandwidth clients can use (0=unlimited, 4000=good to keep dialup gamers off the server)
//   Example : we want unlimited
//   sv_minrate 0
// Maximum updates per second that the server will allow. Increasing this value will take more cpu power, 100 is max.
//   Formula : sv_maxupdaterate = sv_maxrate / 300
//   Example : with same assumptions than above.
//     sv_maxupdaterate = 9600 / 300 = 32
Though it's been a while since I researched it, I believe your high tickrate increases bandwidth usage too (along with CPU physics prediction)
« Last Edit: June 24, 2010, 03:16:15 pm by JamminR »
Offline CDBettler
« Reply #4 on: June 24, 2010, 09:09:26 pm »
Hmm, well thanks for the heads up but i have had more than 5 clients on before, all building miscellaneous contraptions with minimal lag. I'll keep it in mind though.
P.S- My parents don't do anything but surfing the web, they don't mind XD
BTW- I used this site for reference on how many players, my rates, etc. should be set to.
http://planethalflife.gamespy.com/View.php?view=HL2Guides.Detail&id=4&game=3
« Last Edit: June 24, 2010, 09:20:09 pm by CDBettler »
« Reply #5 on: June 25, 2010, 03:21:30 pm »
They use a very similar formula for max rate as to the link I mentioned/found.
PlanetHalfLife states; Bandwidth (in kbps) * 128 / Maxplayers = sv_maxrate
Your upload is 768 kbps.
Your max rate would give you up to six players before lag would be experienced (due to bandwidth)
Love your logo. Fun image.
Offline CDBettler
« Reply #6 on: June 25, 2010, 03:45:54 pm »
Yea, one of the Admins made that for us. Yea, i used that calculation, and that is what my max players is set to haha. But that upload speed is with the server running, on my computer. I'm am always concerned about our clients, i'm always asking, "Hows the server?" and so far, i have no complaints! I'll be sure to let the logo designer know that you mentioned it!  :D
