Author Topic: Names Not showing Up Before Commands  (Read 4677 times)
Offline JulioG
« on: June 25, 2010, 01:51:02 pm »
I've Just Installed the Released Version of Ulx (Not the SVN)
And it isnt showing names before actions.
Like
(ADMIN) added user Tyler to group "owner"
Ulx Doesn't return Errors On Load In The Console
Re: Names Not showing Up Before Commands
« Reply #1 on: June 25, 2010, 02:54:55 pm »
It's how you have your configuration set. I forget the option name, but just go change it in the config.
« Reply #2 on: June 25, 2010, 03:42:08 pm »
Megiddo, I actually don't remember the option controlling names or not.
Thought it just controlled whether or not the item showed publicly at all.
(and sorry Julio, I too don't remember the actual var name)
See your /addons/ulx/cfg/server.ini file, copy it to your gmod/cfg, edit it's options.
« Reply #3 on: June 25, 2010, 03:47:04 pm »
ulx_cl_logEcho 2
It's probably set to 1 currently, which logs it but doesn't show the admin's name.
0 will disable.
Offline JulioG
« Reply #4 on: June 25, 2010, 04:50:06 pm »
Thanks for the replys! That did the trick
« Last Edit: June 25, 2010, 04:55:35 pm by JulioG »
