Author Topic: motd broken  (Read 11229 times)
motd broken
« on: June 29, 2010, 11:18:42 am »
After garrys update the motd seems not to be working on my server.  Everything else works fine though.  It shows some TF2 map cycle.
Re: motd broken
« Reply #1 on: June 29, 2010, 01:04:14 pm »
Garry probably added the motdfile cvar again, just set it to the ulx motd.
Re: motd broken
« Reply #2 on: June 29, 2010, 01:23:02 pm »
I do that how exactly?
Re: motd broken
« Reply #3 on: June 29, 2010, 02:14:49 pm »
I believe it's motdfile "blah" in console.. Could be wrong though.
Also, Megiddo, Noticed an issue with MOTDs that may have been caused by the update (or the above issue)-- If you set ulx_showMotd to a URL, then change it back to ulx_showMotd 1, it will still only show the URL rather than the MOTDfile. Any way to fix that?
Re: motd broken
« Reply #4 on: June 29, 2010, 02:26:25 pm »
So do I have to set it in the servers config?  and do I just put ulx_motd.txt?
Re: motd broken
« Reply #5 on: June 29, 2010, 04:21:08 pm »
A couple of new questions...
What is the location of the motdfile relative to?
and
Do we use motdfile or motdfile_text?
Re: motd broken
« Reply #6 on: June 29, 2010, 05:15:12 pm »
Use motdfile, it's relative to the root directory.
Re: motd broken
« Reply #7 on: June 29, 2010, 05:42:30 pm »
Aell I tried motdfile addons/ulx/ulx_motd.txt and nothing happened.  Are we suppose to put it in cfg? (Server is a little full so kinda hard to try.)
Offline DiscoBiscuit
    • DiscoBuild
Re: motd broken
« Reply #8 on: June 29, 2010, 06:39:32 pm »
Just do ulx_motd.txt not all that other stuff.
Re: motd broken
« Reply #9 on: June 29, 2010, 08:46:56 pm »
Still seems not to be working...
Offline Briam
Re: motd broken
« Reply #10 on: June 29, 2010, 11:28:48 pm »
I can confirm that this isn't working.
It showed some standard counter-strike one at my server. Then i tried overriding the motd.txt in cstrike folder and it just showed white :S. Then i setup a webserver where I can host our motd and wrote ulx showMotd "url" which works
Offline RynO-SauruS
Re: motd broken
« Reply #11 on: June 30, 2010, 01:48:18 pm »
The actual modified custom MOTD file goes straight in the root folder and should be named "ulx_motd.txt"
(I say this because there's a default 'template' thing in addons/ulx that should not be modified),
so to fix this, put this in your cfg/server.cfg file (otherwise it resets itself):
motdfile "ulx_motd.txt"
This is assuming you haven't renamed or moved it.
« Last Edit: June 30, 2010, 01:54:32 pm by RynO-SauruS »
YouTube music player by RynO-SauruS
Re: motd broken
« Reply #12 on: June 30, 2010, 02:05:31 pm »
I figured out my problem, I was thinking superadmins would be able to change it.  After I used rcon it works fine, just seems to be a little wide.
EDIT: Ok I'll put that in the cfg.
Re: motd broken
« Reply #13 on: June 30, 2010, 05:54:51 pm »
Added 'motdfile ulx_motd.txt' to our config to fix it in the mean time, since garry's probably going to end up removing that cvar again at some point.
