Author Topic: Error when using admin menus  (Read 5210 times)
Offline lilneo
« on: June 29, 2010, 07:26:48 pm »
Okay so, I installed ULX and Ulib, everything installed fine it's all good, but when I use ulx adminmenu or ulx banmenu, I get an error
For ulx banmenu I get:
unknown command: 'ulx_getbans'
And then a derma window that says "loading" appears in the middle of my screen and doesn't go away.
for ulx adminmenu I get:
unknown command: 'ulx_valueupdate'
Then the adminmenu opens, but all of the prop limits and everything is set to 0, as if it didn't know what it was actually set to on the server.
Any help would be appreciated
thanks
~lilneo
Re: Error when using admin menus
« Reply #1 on: June 29, 2010, 07:49:08 pm »
What version of ULX? (Release or SVN?)
If SVN, latest revision of _both_ ULib _and_ ULX?
Dedicated or listen server?
In server console at startup when ULib loads, any errors?
Any for client at server connect?
Same two questions as above for ULX?
Offline lilneo
« Reply #2 on: June 29, 2010, 07:56:31 pm »
I am using the most up to date ULX and Ulib (not svn), I'm using srcds, no from the looks of it there is no ULX or Ulib errors. Everything loads fine, I can get you a log if you really need it. And no there is no errors upon conenctions.
~lilneo
« Reply #3 on: June 29, 2010, 09:14:54 pm »
Recent Gmod updates have been problematic with our release version and to be quite honest, I'm surprised ULib initialization may work at all.
However, to my knowledge, our menu's don't have a 'loading' function but it is possible this is a derma function I'm not familiar with.
Are you running other mods? Have you tried removing them temporarily and restarted the server?
Megiddo/Stickly Man/Jay, any input on this? With the new engine updates to Gmod, can we even really support release version?
Would the loading be coming from our menus?
Also lilneo, no need to sign your posts. We know who you are. :)
« Reply #4 on: June 29, 2010, 09:18:31 pm »
The ban menu did have a loading screen, looks like garry's latest updates have just completely crippled the release versions now.
Offline lilneo
« Reply #5 on: June 29, 2010, 10:05:14 pm »
Alright so it was garry, thanks.
And Jamm I like signing my posts =D
Edit: Whatever happened, not sure, but it work fine now. (Never changed anything)
~lilneo
« Last Edit: June 30, 2010, 12:53:57 am by lilneo »
Offline lizzar
« Reply #6 on: June 30, 2010, 10:27:27 am »
I have the same problem :S Seems to load fine but errors appears when opening menus :
Unknown Command: 'ulx_valueupdate'
Unknown Command: 'ulx_cvar'
Unknown Command: 'ulx_getgamemodes'
Using the latest version of ULX & ULIB from the download section of the website, i run it on a 'provider-hosted' server.
[UCL] Access set.
Welcome to                                                    ! We're playing gm_construct.
===  Wire revision: 0     ===
=== Local Wire revision:0 ===
AdvDupeShared: Server Compression: false
Redownloading all lightmaps
This server is running ULib version 2.30.
ULX version 3.40 loaded.
(ADMIN) LizzAr slapped LizzAr with 0 damage
] ulx_valueupdate
What shall I do?
Edit : Im using ulx since around 2 years without any problems -.- installed it like 20 times w/o problems xD
-LizzAr
FIXED , Don't know how but fixed.
« Last Edit: June 30, 2010, 03:23:59 pm by lizzar »
