Author Topic: Can't spawn anything (resolved)  (Read 24039 times)
Offline lizzar
« on: June 30, 2010, 12:09:25 pm »
Hello, im running gmod and ulx/ulib on a rented-server, I have some problems linked to ULX And/Or Ulib. People already said that the addon couldn't interfer with spawning but... when don't load ULX I can spawn props/thrusters/etc... Then I reboot the server WITH ulx and i cannot spawn any props anymore... =(
No error message, nothing.. Looks like i don't have the props installed on the server..
Im using ULX ULIB UTIME UTEAMS UNOLIMITED (haven't tested w/o it... gonna do this right now...) phx wire etc... And uploading both phx and wire takes 3 hours.... So i don't think reinstalling Gmod is a good thing, plus i reinstalled it twice today...
« Last Edit: June 30, 2010, 12:15:20 pm by lizzar »
Offline lizzar
Re: Can't spawn anything
« Reply #1 on: June 30, 2010, 12:14:59 pm »
Okay... Sorry for this dbl post but it is needed !
( Perhaps )UnoLimited_v2 IS BROKEN
Problem solved itself.
« Last Edit: June 30, 2010, 03:20:36 pm by lizzar »
« Reply #2 on: June 30, 2010, 12:15:46 pm »
Perhaps you configured unolimited incorrectly?
Offline lizzar
Re: Can't spawn anything (resolved)
« Reply #3 on: June 30, 2010, 12:19:18 pm »
there is no config file and in the lua there are lines :
UNL.groups = {
superadmin = -1,
admin = 2,
operator = 1.5
its clearly detailed :
-- If you allow sbox 1 of something...any multiplier below 1 will set that groups limit to 0. Any not 2 will be 1.
-- All groups not specified get 'standard' limit set in your server.cfg.
-- Any group set to -1 becomes unlimited
Edit : Im also superadmin... So i would have unlimited but can't spawn anything ;)
« Reply #4 on: June 30, 2010, 01:10:19 pm »
If unolimited is broken as you suggest, then URestrict should also be broken and I don't have any reports of that. I will test when i get to the house though.
Offline lizzar
« Reply #5 on: June 30, 2010, 02:18:06 pm »
Oh well i didnt knew there was a link between Urestrict and Unolimited ;).
Anyway I removed it from the server and now it works perfectly !
But I didnt loaded Urestrict so I cannot say more...
I Hope both aren't broken because they are good ulx addons...
« Reply #6 on: June 30, 2010, 03:04:52 pm »
URestrict seems to be working fine for me.
Offline lizzar
« Reply #7 on: June 30, 2010, 03:34:43 pm »
Hmmm I might be really unlucky because my Urestrict doesn't work. Same problem. :(
I just have this :
ULib\modules\urestrict.lua:271: attempt to index field 'cmds' (a nil value)
« Reply #8 on: June 30, 2010, 06:21:32 pm »
I just have this :
     - You don't have the latest ulx/ULib svn.
« Reply #9 on: June 30, 2010, 08:02:42 pm »
Which would also explain why UNoLimited v2 wasn't working, it too requires SVN of ULib.
Offline lizzar
« Reply #10 on: July 01, 2010, 02:08:39 am »
Omg.. that's true... I uploaded the wrong folder (the non-svn one which I keep as backup) :( this makes sense why it is not exactly the same as before I reinstalled the server ...
Well, I apologize for this thread ! x)
« Last Edit: July 01, 2010, 02:10:15 am by lizzar »
« Reply #11 on: July 01, 2010, 06:26:36 am »
     - No worries, next time though. Please provide ULib version info. Glad we could resolve the issue.
