Author Topic: Player Title II - Name and Title Display  (Read 98083 times)
Re: Player Title II - Name and Title Display
« Reply #30 on: May 26, 2012, 10:46:52 pm »
Sorry for bumping this old? thread but, for some reason I don't get any tag.
I can use the commands (!title, mytitle, settitle...) but the tag/title doesn't appear.
Thanks in advance,
Tom
What do you mean? Right there in the picture it says that you set your title to Help, and then when you checked your title it returned Help.
Offline thegtz
« Reply #31 on: June 20, 2012, 10:03:00 pm »
How do I remove the default name display? Currently i have two names that show above someones head. I would like only one to show up.
Offline lavacano201014
« Reply #32 on: September 08, 2012, 01:47:49 am »
First of all, I have added this text to the OP:
Regarding Developer Support
I don't come onto the Ulysses forums as much as I used to. However, if you add me on Steam (and leave a comment with your problem) I'll gladly try to help you out (though be warned I honestly haven't looked at the code in quite some time). This does not mean Player Title II development is halted. Merely paused.
Regarding GMod 13
The proper response to the question "Does it work in GMod 13" is "I have no idea." I've been meaning to bug the Ulysses team for access to their GM13 codebase but a combination of Megiddo never being on Steam and me having bad memory means I still haven't done it.
Now to answer questions.
Thanks in advance,
Tom
I'm not sure what you're after here, are you wanting the title to appear in the chatbox? Because that's not the intent of this addon. It's supposed to hover over your head when another player looks at you.
Open lua/autorun/client/cl_playertitle.lua and change the variable enablenames to false.
« Reply #33 on: September 08, 2012, 06:50:36 pm »
Lavacano, no need to bug Megiddo for the codebase, see mention here - /index.php/topic,5484.15.html#msg26481 />
« Reply #35 on: September 20, 2012, 11:17:58 pm »
I think you should add that as an option and allow it to be custom, set by an admin, or just the persons rank. In addition this should also have some settings like changing if people can see the name through a wall or the ability to change at what distance the names fade away. You know server side vars and may be more client side vars?
Offline nexbr
« Reply #36 on: November 26, 2012, 03:21:58 am »
Can you create two cvars?
1. Server Side like sv_playertitle_enable 1/0
2. Client Side like cl_playertitle_enable 1/0
Then we can disable the player title to all players or just for me.
Because sometime you want spy some players but the flying title are not stealthy !  ;)
Offline datgregofag
« Reply #37 on: February 12, 2013, 03:49:28 pm »
Hi, how can i change it so that when a person dies it doesn't show the title, i have a ttt server and when someone dies their title still floats around.
Offline krooks
  • I don't like video games.
    • Diamond Krooks
« Reply #38 on: February 17, 2013, 09:42:54 am »
I think when I get some time, I will be adding this to my server. So I'll fix it and give the code when I do (unless someone beats me to it). I would give instructions on how to do it, but I'm not good enough at lua for that, so it will take tinkering :P
My TTT server. Join the fun!
« Reply #39 on: February 18, 2013, 01:45:02 am »
cl_playertitle.lua
Replace the code in this file with this
//Config
// Names enabled?
local enablenames = true
// Titles enabled?
local enabletitles = true
// How to align the text?
// 0 = left
// 1 = center
// 2 = right
local textalign = 1
// Distance multiplier. The higher this number, the further away you'll see names and titles.
local distancemulti = 2
// Don't edit below this point unless you know what you're doing. //
function DrawNameTitle()
local vStart = LocalPlayer():GetPos()
local vEnd
for k, v in pairs(player.GetAll()) do
if not v:Alive() then continue end
local vEnd = v:GetPos() + Vector(0,0,40)
local trace = {}
trace.start = vStart
trace.endpos = vEnd
local trace = util.TraceLine( trace )
if trace.HitWorld then
--Do nothing!
local mepos = LocalPlayer():GetPos()
local tpos = v:GetPos()
local tdist = mepos:Distance(tpos)
if tdist <= 3000 then
local zadj = 0.03334 * tdist
local pos = v:GetPos() + Vector(0,0,v:OBBMaxs().z + 5 + zadj)
pos = pos:ToScreen()
local alphavalue = (600 * distancemulti) - (tdist/1.5)
alphavalue = math.Clamp(alphavalue, 0, 255)
local outlinealpha = (450 * distancemulti) - (tdist/2)
outlinealpha = math.Clamp(outlinealpha, 0, 255)
local playercolour = team.GetColor(v:Team())
local playertitle = v:GetNetworkedString("title")
if ( (v != LocalPlayer()) and (v:GetNWBool("exclusivestatus") == false) ) then
if (enablenames == true) then
draw.SimpleTextOutlined(v:Name(), "TargetID", pos.x, pos.y - 10, Color(playercolour.r, playercolour.g, playercolour.b, alphavalue),textalign,1,2,Color(0,0,0,outlinealpha))
if (not (playertitle == "")) and (enabletitles == true) then
draw.SimpleTextOutlined(playertitle, "Trebuchet18", pos.x, pos.y + 6, Color(255,255,255,alphavalue),textalign,1,1,Color(0,0,0,outlinealpha))
hook.Add("HUDPaint", "DrawNameTitle", DrawNameTitle)
All I did was add an alive check to the player to decide if the title should be drawn above their head. 1 line of code.
if not v:Alive() the continue end
Offline PAL-18
« Reply #40 on: February 18, 2013, 04:46:59 pm »
Screenshot link in first post returns a 403 error ...
« Reply #41 on: February 18, 2013, 07:36:55 pm »
See the date?
Hence, why I wish most folks would attach their small-ish images and files here, and not link them.
Though majority of the time the code/whatever they posted here won't work in Gmod 2 years after release, it would at least give someone chance to review, perhaps pick back up.
Add in links to other sites, and, well, I've seen those change more often than we keep up with Gmod's code changes. :D
(Lavacano doesn't visit these parts too often...last was Nov 1 2012)
« Last Edit: February 18, 2013, 07:38:53 pm by JamminR »
Offline krooks
    • Diamond Krooks
« Reply #42 on: February 19, 2013, 03:01:55 pm »
I haven't tried your code Mr. President, but while messing with this last night I noticed it needs a lot more work than just that to be use on TTT.
As it is, it displays all names in your view, which is really different from TTT, which only displays them within a certain radius of the middle, the names fade in and out depending on distance.
To have them always on would be game changing, as it would be much easier to see the names to call a KOS.
I'll be tinkering with this when I have time, and hopefully release a TTT version of it, unless someone beats me.
Offline pazda
« Reply #43 on: March 05, 2013, 03:19:08 pm »
This breaks my DarkRP server. The new names show up, but the commands don't work, the HUD shows nothing, default class is Connecting/Joining, and the default weapons from classes are gone.. Any ideas?
Offline SatoshiAaron
« Reply #44 on: June 26, 2013, 08:29:31 pm »
How would I stop PRISONER_DEAD and GUARD_DEAD and SPECTATOR Teams tags from being visible. Because we can see them when they are spectating people or when they join the server in the middle of the map.
