Author Topic: Gmod MOTD messed up  (Read 7060 times)
Offline Novac
  • Personal Text...hmm...no.
Gmod MOTD messed up
« on: July 22, 2010, 01:51:55 pm »
My server's MOTD is messed up, it shows up as a TF2 motd, can anyone help me?
I love gaming, it's my hobby, so is pissing people off.
Re: Gmod MOTD messed up
« Reply #1 on: July 22, 2010, 02:00:26 pm »
Is this svn?
Offline DiscoBiscuit
    • DiscoBuild
« Reply #2 on: July 22, 2010, 06:18:47 pm »
motdfile ulx_motd.txt
Offline Novac
« Reply #3 on: July 23, 2010, 05:36:45 am »
No it's not svn. I just edited the motd.txt in the ulx folder, it worked before, but not anymore.
« Reply #4 on: July 23, 2010, 05:43:52 am »
Okay, you'll want to follow Disco's instructions then. Just throw that line into your server.cfg or something and you'll be fine.
Offline Novac
« Reply #5 on: July 23, 2010, 07:50:19 am »
Where exactly do I put it? Doesn't seem to work for me when I put it in the server.cfg, I use a listenserver.
« Last Edit: July 23, 2010, 08:02:46 am by Novac »
« Reply #6 on: July 23, 2010, 08:29:25 am »
What do you mean by doesn't work?
Offline Novac
« Reply #7 on: July 23, 2010, 08:45:08 am »
I still got the same problem even though I put that line in the server.cfg :-\
« Reply #8 on: July 23, 2010, 08:35:21 pm »
Did you move or rename the file? If not, run 'motdfile' in the server console and tell us what the result is.
Offline Novac
« Reply #9 on: July 24, 2010, 01:22:11 am »
I didn't move or rename the file. When I try to run/execute motdfile, all I get is ''Unknown command'' :( And the MOTD still shows up as a TF2 MOTD, if I disable TF2 content in ''Extensions'' at Main Menu, I get a CSS MOTD instead. And as I said before, i'm using a listenserver(Create Multiplayer option).
