Author Topic: UTeam and sui_scoreboard_modified_v2  (Read 4611 times)
Offline zapwnee
« on: August 06, 2010, 04:40:41 pm »
So I got both today. I edited the UTeam text document so I can make some teams and what not. Then when I get into the server and press tab the list stays on my screen and it's blank.
I get this repeatedly after I press tab:
sui_scoreboard\player_row.lua:128: attempt to call method 'GetUTime' (a nil value)
Don't flame me if it's a stupid simple fix, I'm new to this.
I want to know what is wrong.
Re: UTeam and sui_scoreboard_modified_v2
« Reply #1 on: August 06, 2010, 04:51:37 pm »
Sui_scoreboard is an old release.
Many authors edited it and released there own version of it.
I've no idea which version you have..can't find that specific title in the community releases here.
However, it sounds like you have a version that requires UTime ... a time tracking release made by Megiddo of Team Ulysses.
It's also available in our releases section.
UTeam is not the same as UTime
Read the information at the release area sui you downloaded, I bet it says what all is required. (UTime, etc)
Offline zapwnee
« Reply #2 on: August 06, 2010, 05:02:21 pm »
lol the scoreboard name was the name of the folder. Sorry if it was confusing, but it is the (I think) latest one made by BMCha. I will download UTime and see if it fixes. Thank you for the info.
« Reply #3 on: August 06, 2010, 05:23:18 pm »
Ah, ok. /index.php/topic,3650.0.html
Yes, even in BIG BOLD print, he mentions making a non-UTime required version.
There are two links.
If you don't want the one that requires UTime, use the non-UTime link.
Make sure to read later on in any sui_scoreboard release topic area.
Much of the reason it's been remade so many times is not only for enhancement, but also because it seems several have broken over time of Gmod, usually due to Gmod uipdates/code changes by Garry.
You might find in later pages fixes to code that are made by others if they can't reach the original releaser.
Offline zapwnee
« Reply #4 on: August 06, 2010, 06:02:55 pm »
Well thank you for the support. It works now.
