Author Topic: A quick Lua beginners tutorial  (Read 6598 times)
Offline Golden-Death
  • Honored Lua Scripter
    • BlueFire
« on: November 01, 2006, 06:56:32 pm »
The_fool asked me how I learned lua, So I told him the basics. I didn't work very hard on this, but maybe it'l inspire some of you like it did me.
i learned it by just fooling around. its pretty easy.
for example, you open this:
http://gmwiki.garry.tv/index.php/Lua
it has everything you need.
then you see 2 sections:
Engine Bindings
and
Hooks/Events
Hooks and events are used to tell when a function is run. Ex, "When a balloon is popped" is a hook/event.
Bindings do things like set health.
So click on Engine Bindings and find something that looks cool. For example,
_PlayerSetHealth - Changes a player's health. Syntax: <playerid> <newhealth>
Looks good. Lets go back and find a hook to use
eventNPCKilled - An NPC is killed. Syntax: <killerid> <killed>
That works well too. So now open notepad and enter this:
function eventNPCKilled
CAPS DO MAKE A DIFFERENCE, use correct capitalization
'function' means that the following is an EVENT or FUNCTION
now remember it said this:
those mean that when the function is called (ie, an npc dies) it will give you those values. so they must be assigned to variables. Edit what you entered to read this:
function eventNPCKilled(killer,killed)
This means that the killer (<killerid>) will be stored in the variable 'killer' and so on.
Now we can use our binding.
We add this line below the last one, doing the same thing, except this doesnt give you information, it needs information, so we must suply it with the proper info.
_PlayerSetHealth(killer, 150)
This means that the variable stored as 'killer' will equal the player who gets the health. (ie, the player who killed the npc)
150 means that we are setting his health to 150.
Now we add an 'end' to tell the game that our function is now over.
It should look like this:
save it as a .lua file in gmod9/lua
run the game, lua_openscript it, and kill an npc.
« Last Edit: November 01, 2006, 06:59:31 pm by Golden-Death »
Re: A quick Lua beginners tutorial
« Reply #1 on: November 02, 2006, 05:02:59 pm »
One thing I learned quickly was to use HookEvent when using event stuff.
(Can't be used in SWEPS)
If you don't, and have multiple scripts already, you're likely not to have the event cause a reaction.
Or, yours will work, but another scripts won't.
    • BlueFire
« Reply #2 on: November 06, 2006, 03:20:32 pm »
Yeah, I just start out with it since its easier to see how it works.
