Author Topic: Constant Unauthed errors  (Read 3671 times)
Offline Fribble
  • I'm no good
    • My roleplay server on GMod
« on: August 12, 2010, 01:11:56 pm »
Well when I join my server I am constantly 'unauthed'. This has never happened with any of my other admins. It is a ulib error, if you need to know that. Can anyone tell me the problem?
:o
Re: Constant Unauthed errors
« Reply #1 on: August 12, 2010, 04:10:18 pm »
Fribble, this was recently found on a server due to an SVN update where Megiddo failed to unlink a file that had been removed..
Recent SVN versions should have fixed this.
Are you running SVN? Is it the latest?
Are you running dedicated server?
 Or listen server?
Also, if you are running latest SVN and are connected to your dedicated server, it is possible and likely that a mod you have installed (but your admins may not) is out of date (or just plain written badly) and causing issues with ULX.
