Author Topic: Little Question.  (Read 9086 times)
Offline xmathewx75
Little Question.
« on: August 12, 2010, 07:15:23 pm »
Hello, i will no longer bother you people for stupid questions sorry about that.
but i need to know some stuff please. okay.
1) how do i make make my admins use anything that was blocked or go pass prop limit?
2) how do i block some stuff?
3) how do i make my admins have access to holding players or shipments with phys gun?
thanks for help i promise last stupid post!
Re: Little Question.
« Reply #1 on: August 12, 2010, 07:48:50 pm »
'anything' and 'stuff' are generally questions we can't answer. Poke through the release section to see what we have available. If you have more specific questions, we'd love to help. In #3, I don't know what you mean by shipments, but ULX has a feature to physgun other players already.
Offline xmathewx75
« Reply #2 on: August 12, 2010, 08:09:33 pm »
okay but how do i make admins have access to everything like, a prop is disabled a admin still can use it or go pass prop limit how i do that?
« Reply #3 on: August 12, 2010, 08:57:54 pm »
There are two releases that cover that behavior, UnoLimited and UPPL.... but I don't think they can be used together. Worth trying it out, I guess.
« Reply #4 on: August 12, 2010, 09:44:15 pm »
Asking questions isn't stupid.
However, that being said, asking questions that could have been found easily, have already been answered, and in many cases regarding your questions were told where to look already, does indicate issues with learning from questions/mistakes already made.
I'm pretty sure we've mentioned one release in particular that if you would simply read that releases post would answer majority of the questions you've asked.
I believe it has features of UPPL, and I know darn well it includes the idea behind UNoLimited because the author and I (I posted UNoLimited) had some major discussion about why I did things the way I did.
Offline xmathewx75
« Reply #5 on: August 18, 2010, 04:54:57 pm »
where can i download UnoLimited and UPPL?
« Reply #6 on: August 18, 2010, 06:26:43 pm »
From main forum front page, see the "Releases" section.
Offline xmathewx75
« Reply #7 on: August 18, 2010, 10:01:59 pm »
Thank you very much. But i have a question, I installed Darkrp 2.4.1 but when i spawn a shipment for a example. I can't even hold it with my Physgun and i wanna be able to hold it with my Physgun. Can you please help?
« Reply #8 on: August 19, 2010, 06:33:48 am »
Please take this discussion to the UPS thread.
Edit: Er, sorry, not sure why I assumed you were using UPS. If you're not using UPS, this is something you should take up with the DarkRP author.
« Last Edit: August 19, 2010, 09:12:56 am by Megiddo »
Offline xmathewx75
« Reply #9 on: August 19, 2010, 12:13:30 pm »
thanks it helped me there to =) but one more thing again how do i set a spawn point?
« Reply #10 on: August 19, 2010, 03:01:32 pm »
Setting a spawn point is not something any of our software can do (that I remember, anyways).
« Reply #11 on: August 19, 2010, 05:36:50 pm »
Ah, there it is, I knew atomicspark had a spawnpoint plugin somewhere:
/index.php/topic,4228.0.html
Offline xmathewx75
« Reply #12 on: August 19, 2010, 07:25:26 pm »
Thanks. One more thing again :p Some reason now i can only spawn props and shipments, etc but something is wrong i cant hold it with my physgun idk what happened it gotta be prop protection but i don't know where to find "Prop protection" please help again  ;)
