Author Topic: *Solved*XGUI Not Working (Your ULX player has not been Authed.)  (Read 13257 times)
Offline MrBotox
Hey I have installed XGUI and it seems its having problem's Authenticating me, I'm not sure whats causing this, its probably something real simple.
Heres some info you might need.
Im Running a Dedicated Server
Latest Version of ULX SVN
And im the owner :3
And Heres a pic of what is coming up when i type !xgui in the chat (I have waited a few seconds and more still same problem)
Sorry if this was already posted and Hope you can Help me :3
Regards,
MrBotox  :)
« Last Edit: August 13, 2010, 01:18:28 pm by MrBotox »
Re: XGUI Not Working (Your ULX player has not been Authed.)
« Reply #1 on: August 13, 2010, 07:33:43 am »
Do all players on your server have the same issue? If so, what's the IP of your server so I can check it out?
Offline MrBotox
« Reply #2 on: August 13, 2010, 11:40:48 am »
Yeah for all people i think anyway. the ip is 90.212.127.4
« Reply #3 on: August 13, 2010, 12:04:39 pm »
Hmm, I just connected multiple times and got authed just fine :-\
Are you sure you have the latest versions of ULX/ULib? And do you happen to have an older version of ULX/ULib installed on your client?
If you have time to do so, could you try temporarily removing all of your addons from your client and see if it helps? (You'll have to restart gmod after you move the addons out of your addons folder to somewhere else)
Offline MrBotox
« Reply #4 on: August 13, 2010, 12:14:45 pm »
Yes i do have an older Version, i will try removing all my addons now and Report back :3
« Reply #5 on: August 13, 2010, 12:19:27 pm »
You should try removing just the older version of ULX/ULib  first (or update them to the latest SVN), as I think conflicts between your clientside files and serverside files are causing the problem.
Offline MrBotox
« Reply #6 on: August 13, 2010, 12:22:34 pm »
Yup That fixed it :3 Thanks for the help!
« Reply #7 on: August 13, 2010, 12:22:57 pm »
You're welcome, Glad I could help!  ;D
Re: *Solved*XGUI Not Working (Your ULX player has not been Authed.)
« Reply #8 on: December 30, 2010, 05:16:13 pm »
I split a new topic posted here: /index.php/topic,5097.0.html
