Author Topic: Adding maps to ULX Votemap  (Read 7850 times)
Offline Rogue
« on: August 23, 2010, 12:33:53 am »
Hi there,
I have searched around but can't seem to figure this one out. I have a TTT server using ULX and have CS:S and TF2 content installed how ever none of the TF2 or CS:S maps show up under the ULX Votemap list, only the ones which are in the garrysmod/maps folder do.
I don't really want the TF2 maps to show up, so I was wondering how do I make the CS:S maps show up as well as the ones in my gmod folder (I don't want the default gmod maps however)?
Thanks!
Rogue
Re: Adding maps to ULX Votemap
« Reply #1 on: August 23, 2010, 07:44:57 am »
Is this a Linux server? All maps should up by default unless it's a Linux server.
Offline Rogue
« Reply #2 on: August 23, 2010, 08:36:52 am »
Yep it is a Linux server. So is there any way to fix it in that case?
« Reply #3 on: August 23, 2010, 08:49:10 am »
If you make the names on all the maps lowercase, it should work.
Offline Rogue
« Reply #4 on: August 24, 2010, 09:13:17 pm »
Hmm, I just checked the map names in both CS:S and Gmod and all names are lowercase so they should be showing up... however they are not.
« Reply #5 on: August 24, 2010, 09:25:34 pm »
Could we remotely debug your server sometime tomorrow? Contact me on Steam and we can work out a time.
Offline Rogue
« Reply #6 on: August 26, 2010, 06:38:51 am »
How do I contact you on Steam?
What is your username? PM me perhaps, in case you don't want to post it on a public forum.
I only have FTP/Game panel access, I hope that is enough.
« Reply #7 on: August 26, 2010, 01:43:31 pm »
MegTech is my username
