Author Topic: ULX menu Broken  (Read 6683 times)
Offline Bikeinator
ULX menu Broken
« on: September 06, 2010, 03:07:41 am »
Hi i gave myself admin and i can use the ulxes eg !slay name and the rest but when i do any of the menus it dosent work
Re: ULX menu Broken
« Reply #1 on: September 06, 2010, 06:47:42 am »
The regular ULX menu? Any errors in console?
Offline Bikeinator
Re: ULX menu Broken
« Reply #2 on: September 06, 2010, 11:54:22 pm »
all of the menus
Bikeinator: !menu
[ULIB] Error, received invalid lua
this only happened on the !menu one
But at one time a gray box came up with only a X on it
« Last Edit: September 07, 2010, 02:38:13 am by Bikeinator »
Re: ULX menu Broken
« Reply #3 on: September 07, 2010, 11:37:00 am »
Do the regular commands work?
Offline Bikeinator
Re: ULX menu Broken
« Reply #4 on: September 07, 2010, 11:17:51 pm »
Re: ULX menu Broken
« Reply #5 on: September 08, 2010, 04:57:03 pm »
Please use the search box from front page to find any number of posts regarding search term "invalid lua", but basically 3 topics;
All of them relate to 1) download cache not having latest ULib and ULX SVN code, 2) not using SVN of both, and or 3 ) Gmod updates over the past 3 years that have broken our "release" version of ULib and ULX.
Though I didn't take long enough to read all the search listing results, I could also imagine another mod conflicting with ULib.
Where did you get the files, our downloads page, or SVN? If SVN, did you get both ULib and ULX?
If SVN, did you delete the old release code before checking out SVN?
See the other search results, many other fixes for your error, I believe all of which worked for one person or another.
Offline kulcris
Re: ULX menu Broken
« Reply #6 on: September 08, 2010, 07:06:14 pm »
had the same problem all i had to do was remove assmod (make sure you dont have it)
Offline OneWingedAngel82302
  • So... Freakn...Bored....
Re: ULX menu Broken
« Reply #7 on: September 09, 2010, 07:33:51 am »
Yeah, I;m getting the same problem here as well....
[@addons\ulib\lua\ulib\shared\sh_ucl.lua:51] [ULIB] Unauthed player
Note that I Try all my mods (including ULX and ULIB) In single player first before throwing them into my Dedicated Server.
Re: ULX menu Broken
« Reply #8 on: September 09, 2010, 07:36:48 am »
You mentioned you use Xenon Servers in an earlier post, please see my post HERE and see if it helps you out.
