Author Topic: ULX/Ulib Unauthed Player error (SVN)  (Read 6630 times)
Offline Spyster
« on: September 12, 2010, 12:54:03 pm »
I keep getting that unauthed player error although I am in the users.txt (In settings)
Its a hosted server.
I seem to be getting this error before it.
ERROR: Hook 'ThinkForVoiceMute' tried to call a nil function!
Removing Hook 'ThinkForVoiceMute'
Help would be appreciated.
« Last Edit: September 12, 2010, 12:56:58 pm by Spyster »
Re: ULX/Ulib Unauthed Player error (SVN)
« Reply #1 on: September 12, 2010, 12:59:15 pm »
Spyster, where did you get your SVN from? Your host? Or us?
We've seen recent host that doesn't keep up to date. Make sure you're getting it using the SVN access info instructions.
As for that error, I'm not sure it's a ULib function. (Though, I don't currently have SVN installed to verify)
Running other admin mods? They may be conflicting.
Offline Spyster
« Reply #2 on: September 12, 2010, 01:10:51 pm »
Im running Assmod, for tool restricting.
Ive seen another server use the combo and they didnt conflict.
I got it from your ULX that I uploaded to the server via FTP.
Using the http://ulyssesmod.net/ulx/trunk/
and http://ulyssesmod.net/ulib/trunk/
« Reply #3 on: September 12, 2010, 01:27:27 pm »
Can you contact me on Steam? My email for my steam account is megiddo@meg-tech.com
Offline Spyster
« Reply #4 on: September 12, 2010, 01:33:55 pm »
Already did that  8)
Edit: It seems when I tried to add you again after deleting you, Steam said there was a problem.
« Last Edit: September 12, 2010, 01:50:11 pm by Spyster »
Offline Spyster
« Reply #5 on: September 13, 2010, 02:30:57 pm »
Since I an unable to contact you in any way, you could suggest to me another way of communication.
« Reply #6 on: September 13, 2010, 07:02:17 pm »
Steam is the best way. If you're having trouble adding friends, you should talk to Steam support... https://support.steampowered.com/
Offline Fleamonji
« Reply #7 on: September 29, 2010, 06:39:28 pm »
getting this too, added you on Steam ('Banana)
Offline lavacano201014
« Reply #8 on: October 08, 2010, 06:59:52 am »
I'll try adding you in case it's something on your end, Megiddo (doubt it)...OK, it worked. Odd.
