Author Topic: Unauthorized access :S  (Read 24489 times)
Re: Unauthorized access :S
« Reply #30 on: September 22, 2010, 03:24:22 pm »
This server is running ULib version 2.03.
Ancient version of ULib.
If you're using release downloaded from our www.ulyssesmod.net download page,
ULib = 2.30
ULX = 3.4
If you use SVN, and I recommend SVN, those numbers, I believe, are higher.
Offline The Zero
« Reply #31 on: September 23, 2010, 05:08:13 am »
I have svn installed... i never installed 2.03 .. it says that.. but i never.. I even uploaded info file on one of my posts to prove it... i dont know why it says 2.03 .. but i have 2.50 ..
edit: i mean 3.50 and ulib 2.40
« Last Edit: September 23, 2010, 05:12:27 am by The Zero »
« Reply #32 on: September 24, 2010, 10:22:57 pm »
I currently don't have Steam/Gmod or dedicated server srcds installed, can someone else confirm the SVN of ULib doesn't erroneously state "this server is running ULib 2.03" when you connect to a ULib SVN server.
« Reply #33 on: September 25, 2010, 08:17:16 am »
It correctly states "You are running ULib version 2.40."
« Reply #34 on: September 25, 2010, 10:36:54 am »
TheZero, as I've believed, and from what I've read, Megiddo has too since some of the beginnings of this thread, your server has old version.
The error you're getting was known in old versions, which is why we've asked you to totally wipe ULib and ULX from your server addons folder and try again.
Perhaps you've installed newer, but someway, your server has mixed files that are old.
Other than makeing sure you wipe old addons/ulx and addons/ulib and then re-install newer code, I know of no other way to help you.
Wipe your local game client addons/ulx and /addons/ulib just to be sure too.
