Author Topic: urestrict question  (Read 4624 times)
Offline luke9511
urestrict question
« on: September 26, 2010, 03:43:32 pm »
hello everyone, I did a search of the forums and couldnt find an answer to my question, which is, how do I block certain weapons on my server, like the css weapons and some weapons from the stargate mod. I tried blocking the stargate staff weapon but that blocked other sweps from the mod I dont want blocked, is there anyway to do this? thanks for any help or advice :)
Re: urestrict question
« Reply #1 on: September 26, 2010, 07:39:49 pm »
In developer to normal user english, loadout = weapon list.
See instructions from the URestrict thread (and, it would actually be best if you asked questions regarding a release within the releases thread)
Creating Loadouts
1: Type URestrict in the console
2: Open the loadouts tab
3: Click Add ( Middle Column )
4: Type in a name for your loadout ( Text box appears after clicking add )
Changing Group Loadouts
3: Select what group you want to modify ( Column on the far left )
4: Select what loadout you wan that group to use ( Column in the middle )
5: Click apply ( Middle Column 3rd button from the bottom )
Modifying Loadouts
3: Select what loadout you want to modify  ( Column in the middle )
4:   To Remove Items From The Loadouts
      1: Select what items you want to remove (Column on the right )
      2: Click modify ( Column on the right )
5:   To Add Items To The Loadouts
      1: Click modify ( Column on the right )
      2: Type in what you want to add ( Text box appears after clicking modify)
Offline luke9511
« Reply #2 on: September 27, 2010, 02:52:16 am »
i have already tried that and it didnt work, i cant seem to get the weapons to be restricted, also i asked here cause it is the help and support forums and i did need help and support
