Author Topic: What kinds of pictured can I embed in the MOTD?  (Read 6398 times)
Offline superspiderman123
« on: September 28, 2010, 01:53:27 am »
I've tried jpgs, bmps, pngs, and all of them give me a box with a question mark inside.
I've been using
<img src="bg.jpg" />
Is there anywhere I need to put the image? Right now, it's just sitting in addons/ulx along with ulx_motd.txt
Re: What kinds of pictured can I embed in the MOTD?
« Reply #1 on: September 28, 2010, 09:06:34 am »
You can use pretty much any type of image, but you'll need to host it somewhere online. imageshack.us is a good choice.
« Reply #2 on: September 28, 2010, 03:06:47 pm »
As Megiddo says in other words, there is no way to 'embed' an image into a Source motd.
Just link to them hosted on a real web server.
Offline RunEndless
« Reply #3 on: September 29, 2010, 09:51:35 am »
Use imageshack or create a webserver.
<img src="Image.jpg" width="192" height="285" />
OR
<img src="Image.jpg" />
Scripting a PHP.
class ULX {
       function ULX_N_PHP($string) {
              echo $string;
} $ULX = new ULX;
$ULX->ULX_N_PHP('PHP + OOP with MySQL is fun.');
« Reply #4 on: September 29, 2010, 10:11:07 am »
OR
You would want to make sure you included the entire path to the image.. like
<img src="http://myhost.com/images/image.jpg">
*edit* -  apparently SMF allows you to use img HTML tags in your post.. go figure.
Offline lavacano201014
« Reply #5 on: October 08, 2010, 06:56:49 am »
test
That's odd. Most SMF forums have that turned off..
« Reply #6 on: October 08, 2010, 07:11:15 am »
I have it turned on because it can't do any harm and it's convenient :P
