Author Topic: Text floating plugin (ULX v2)  (Read 20849 times)
Offline Golden-Death
  • Honored Lua Scripter
    • BlueFire
« on: November 05, 2006, 11:28:13 am »
Original thread:
/index.php/topic,50.0.html
I didn't think any one wanted it, but since Ltp0wer requested it, here it is.
New Features
  • Works with ULX v2
  • No more cvars. (See below)
  • Supports more than one text (Used to be overwritten if you used more than one at a time)
Limitations
  • Running two texts on a player will make them overlap, you'll have to clear all other texts to start new ones, or if you can make it disappear in another manner
  • Can only remove everyone's text. Not one at a time. Maybe some one can figure out a system, because don't have enough time sadly.
Usage:
Say:
!text (player) (red) (green) (blue) (transparency) ("message")
Example:
!text gol 255 0 0 255 "I am an admin"
Remember, quotes are needed on the message part if it contains spaces.
Have fun!
http://ulyssesmod.net/gd/ulxv2scripts/textfloat/ulx_textfloat.lua
« Last Edit: November 05, 2006, 12:06:04 pm by Golden-Death »
Re: Text floating plugin (ULX v2)
« Reply #1 on: November 05, 2006, 11:29:09 am »
Download?
    • BlueFire
« Reply #2 on: November 05, 2006, 12:45:53 pm »
 Download links are overrated :P
« Reply #3 on: November 05, 2006, 01:33:17 pm »
Good job GD!
Offline Ltp0wer
  • Silent
« Reply #4 on: November 08, 2006, 04:16:45 pm »
Haha, sweet.
Exactly what I wanted.
Thanks man, A+ job.
    • BlueFire
« Reply #5 on: November 09, 2006, 10:11:22 pm »
 8)
Offline Ltp0wer
  • Silent
« Reply #6 on: November 13, 2006, 03:39:10 pm »
I have an idea. I'd like if I was able to float text on props aswell.
Like, what you are pointing at, you'd type "!proptext 255 255 255 255 MESSAGE"
Just a thought.
    • BlueFire
« Reply #7 on: November 13, 2006, 05:29:13 pm »
Well, I could just change a few lines of code, I don't know if it will work though.
use !textprop (player who is looking at prop) (red) (green) (blue) (alpha) (message) (z offset)
where the Z offset is how high above the prop it floats, since the prop size will vary. (Players head height is 35 or so)
--             Do Not Edit Below: Use the cvars to set            --
function cc_ulxtextfloatprop( userid, args, argv, argc )
if argc < 7 then
ULib.tsay( userid, ulx.LOW_ARGS )
return
local targets, err = ULib.getUsers( argv[ 1 ], _, true ) -- Enable keywords
if not targets then
ULib.tsay( userid, err )
return
for _, v in ipairs( targets ) do
  _GModText_Start( "Default" );
  _GModText_SetColor( argv[2],argv[3],argv[4],argv[5]);
  _GModText_SetTime( 9999, 0.5, 0.5 ); --How long it stays, and the fading times
  _GModText_SetEntityOffset( vector3( 0, 0, argv[7] ) ); --Messages appear 35 Units above Players
local trace = PlayerLookTrace(v, 9999)
local fent = _TraceGetEnt();
  _GModText_SetEntity( fent ); --Entity/Player the message will follow
  _GModText_SetText( argv[6]); --Set the message
  _GModText_Send( 0, math.random(1,500) );
function ulx.cleartext(userid, args, argv, argc )
for i=1, _MaxPlayers() do
if IsPlayerOnline(i) then
_GModText_HideAll(i)
ulx.CONCOMMAND( "textfloatprop", cc_ulxtextfloatprop, "<user><red><green><blue><alpha><message><location offset in Z> Set text above players", ACCESS_SLAY, "!textprop" )
ulx.CONCOMMAND( "cleartext", ulx.cleartext, "Remove all text floating around", ACCESS_SLAY, "!cleartext" )
Offline Ltp0wer
  • Silent
« Reply #8 on: November 13, 2006, 05:44:03 pm »
if argc < 7 then
return
if not targets then
return
But will that still allow me to do it on players?
