Author Topic: Broken MOTD?  (Read 6453 times)
Offline YoUrWoRsTnIgHtMaRe
Broken MOTD?
« on: October 23, 2010, 09:16:43 pm »
Well on a server I assist in hosting, an motd is displayed that is not the one found in addons/ulx. It is a day of defeat source one. It says ULX motd at the top so Im not sure whats going on. I was just curious if you know where I can locate this motd that seems to be overwriting ours. Thanks
Re: Broken MOTD?
« Reply #1 on: October 23, 2010, 09:41:28 pm »
Though I thought we had it in the readme, I see now we don't.
Try in your <gmod server>/ulx_motd.txt , not <gmod server>/addons/ulx.
If that doesn't work, try <gmod server>/motd.txt
I found a changelog mentioning we'll use ulx_motd.txt, but no inidication exactly where.
If neither of those work, on your server console, type "find motd", one of those will be a path statement showing where Gmod is showing from by default.
Re: Broken MOTD?
« Reply #2 on: October 23, 2010, 09:54:54 pm »
Yes I have the ulx_motd.txt file, but its not showing up at all
I cannot find another motd either.
Re: Broken MOTD?
« Reply #3 on: October 24, 2010, 07:47:34 am »
I know you have the file, but did you copy it from /addons/ulx to your root gmod folder?
<gmod>/file goes here
Also, on your server when you type "find motd", there is no response?
Re: Broken MOTD?
« Reply #4 on: October 24, 2010, 09:54:30 am »
And I think the convar for it is 'motdfile' if you need to change the location.
