Author Topic: "attempt to index upvalue 'glon'" errors  (Read 8648 times)
Offline psycix
« on: October 24, 2010, 01:45:35 pm »
Hello
After the recent update of gmod things screwed up. I thought, oh I should just update the ULX and Ulib and it should be fixed. It didn't.
I installed the latest version of ULX and Ulib (the most recent svn) and it spams these errors on joining or when using !menu:
[ulib\shared\datastream.lua:188] attempt to index upvalue 'glon' (a nil value)
[ulib\shared\datastream.lua:209] attempt to index upvalue 'glon' (a nil value)
Also, most fuctions of ULX do not function anymore.
If a clean install of the addons doesn't work, then I don't know how to fix it, clear data folder?
So what is causing this?
Thank you for your time, psy
Re: "attempt to index upvalue 'glon'" errors
« Reply #1 on: October 24, 2010, 01:52:06 pm »
Did you remove glon from your server or client somehow? You should have a file "garrysmod\lua\includes\modules\glon.lua". Does it still exist?
