Author Topic: Add users in users.txt  (Read 4655 times)
Offline eric1555
« on: December 23, 2010, 01:07:52 pm »
If I made a custom group such as "donator", how would I add them in users.txt (under settings)
My current layout:
"Users"
// This is your users file
// You can use this file to add people as admins on your server
// Add them to the relevant section
// If you're a Lua coder you can add your own sections and use them
// in your script by doing pl:IsUserGroup( "admin" ) etc
"superadmin"
"Ryan" "STEAM_0:1:12150295"
"admin"
"Dokter L. Frieden" "STEAM_0:1:9479656"
"Psychelldic" "STEAM_0:0:20390684"
"Kontra" "STEAM_0:0:20552194"
"StealthHawk69" "STEAM_0:1:17430020"
"Nicomedo" "STEAM_0:1:13695153"
"Sinatra" "STEAM_0:1:25510838"
Re: Add users in users.txt
« Reply #1 on: December 23, 2010, 04:43:19 pm »
For now, I'm leaving this here. However, technically, you're asking a non-ULX related question (Off-Topic).
ULX uses it's own user and group files, imported from the file you're currently asking about/working with that Gmod uses.
You'd simply add an extra set of brackets inside the main two "Users" brackets
http://wiki.garrysmod.com/?title=Player_Groups
Don't add yourself twice. It confuses some poorly made scripts. (Leave yourself in the superadmin part, not admin)
Code below leaves out all the // comments.
"Users"
   "superadmin"
      "Ryan"         "blah"
   "admin"
      "blah1"         "STEAM_blah1"
      "blah2"         "STEAM_blah2"
   "donator"
      "dblah1"         "STEAM_blah1"
      "dblah2"         "STEAM_blah2"
{/code]
