Author Topic: Disable Prop console message  (Read 6132 times)
Offline eric1555
« on: December 28, 2010, 02:22:12 pm »
How do I disable when someone spawns a prop its printed into console?
Example:
Jokkocze<STEAM_0:1:11465275> spawned model models/weapons/w_shot_shottytre.mdl
Re: Disable Prop console message
« Reply #1 on: December 30, 2010, 05:23:47 pm »
Change the following by hand in your config, or use XGUI to change it for you.
Quote from: config
ulx logSpawnsEcho 1 ; Echo spawns to players in server. 0 = off, 1 = Admins only, 2 = All players. (Echoes to console)
« Last Edit: December 30, 2010, 08:21:29 pm by Megiddo »
« Reply #2 on: December 30, 2010, 07:17:00 pm »
Bit more clarification -
The configs are in
your_gmod/data/ulx/config.txt
(Other files in that folder too)
Most are well commented.
Offline sweetone
« Reply #3 on: January 13, 2011, 08:11:21 am »
It still show the lines on console. It just disables log writing.
« Reply #4 on: January 13, 2011, 08:57:10 am »
You want it disabled in the server console, as well?
Offline sweetone
« Reply #5 on: January 13, 2011, 05:24:42 pm »
Yeah. Sometimes there is too many of them and it lags. Also some errors on console are annoying. :(
« Last Edit: January 13, 2011, 05:33:02 pm by sweetone »
« Reply #6 on: January 13, 2011, 10:57:09 pm »
There's actually no way to disable it from the console right now, but I'll probably add that before the next release. What do you mean by errors on console?
Offline sweetone
« Reply #7 on: January 14, 2011, 05:32:46 am »
Thanks. One time there happened some error with wire and then it spammed a lot. I show it you when i see it again.
« Reply #8 on: January 14, 2011, 02:10:47 pm »
Meh, no need for the wire error unless ULib/ULX files are actually mentioned in it.
