Author Topic: SUI Scoreboard  (Read 8981 times)
Offline hymsan
SUI Scoreboard
« on: January 22, 2011, 10:06:29 am »
And to reopen this topic, and annoy you guys by posting off-topic questions, I use SUI Scoreboard with Utime, (love it.) but sometimes we get this,
[@sui_scoreboard\player_row.lua:43] Tried to use a NULL entity!
Any clue what causes it?
« Last Edit: January 22, 2011, 11:00:40 am by Megiddo »
Re: SUI Scoreboard
« Reply #1 on: January 22, 2011, 08:10:54 pm »
You should have posted this in the thread under Releases, but that error happens when you have the scoreboard open and a player leaves.  I haven't really look much into it myself as it isn't a very big issue.  Unless the creator tries to fix it, I'll try myself later.
EDIT:  I think I see the problem.  I'll try it out tomorrow on my server and see if it really was the problem.
« Last Edit: January 22, 2011, 08:21:42 pm by Aaron113 »
Re: SUI Scoreboard
« Reply #2 on: January 22, 2011, 09:08:23 pm »
There are actually a few minor issues with sui_scoreboard.. I'm wanting to take a stab at fixing it up and making it run better with UTeam and whatnot.. someday.. when I get some time :-\
Offline hymsan
Re: SUI Scoreboard
« Reply #3 on: January 23, 2011, 02:22:59 pm »
Megiditto moved the topic to this forum. And thanks.
Re: SUI Scoreboard
« Reply #4 on: January 23, 2011, 07:32:32 pm »
Ahhh
Anyway, I haven't had a chance to try my fix as I ended up being busy today.
Re: SUI Scoreboard
« Reply #5 on: January 24, 2011, 12:43:59 pm »
Hmm, I forgot I can merge topics...
Oh well.
Re: SUI Scoreboard
« Reply #6 on: January 25, 2011, 09:41:21 am »
I have somewhat fixed it.  All you have to do is add some lines into one of the files.
In the file "sui_scoreboard_modified_v2/lua/sui_scoreboard/player_row.lua"
Add after line 42 "if not self.Player:IsValid() then return end"
Seems like it is kind of sloppy to me, but I'm sure Stickly Man will clean it up/improve it when he has time.
It was returning a NIL value.  So, I added this in to make sure the player is valid before setting colors and whatnot.  You'll see a gray box and some words reading "Label"for a short time after a player leaves and I'm not sure why atm, but it does get rid of the errors.
« Last Edit: February 06, 2011, 02:41:24 pm by Aaron113 »
Offline hymsan
Re: SUI Scoreboard
« Reply #7 on: January 25, 2011, 09:06:28 pm »
Thank you Arron, that will improve one of the current issues I have on my community server, You sir, deserve a cookie.
if ( self.Player:Team() == TEAM_CONNECTING ) then
color = Color( 100, 100, 100, 155 )
elseif ( self.Player:IsValid() ) then
//if ( team.GetName(self.Player:Team() ) == Unassigned) then
if ( tostring(self.Player:Team()) == tostring("1001") ) then
color = Color( 100, 100, 100, 255 )
tcolor = team.GetColor(self.Player:Team())
color = Color(tcolor.r,tcolor.g,tcolor.b,225)
elseif ( self.Player:IsAdmin() ) then
color = Color( 255, 155, 0, 255 )
if ( self.Player == LocalPlayer() ) then
color = Color(tcolor.r,tcolor.g,tcolor.b,255)
if ( self.Open || self.Size != self.TargetSize ) then
draw.RoundedBox( 4, 18, 16, self:GetWide()-36, self:GetTall() - 16, color )
draw.RoundedBox( 4, 20, 16, self:GetWide()-40, self:GetTall() - 16 - 2, Color( 225, 225, 225, 150 ) )
surface.SetTexture( texGradient )
surface.SetDrawColor( 255, 255, 255, 100 )
surface.DrawTexturedRect( 20, 16, self:GetWide()-40, self:GetTall() - 16 - 2 )
draw.RoundedBox( 4, 18, 0, self:GetWide()-36, 24, color )
surface.SetDrawColor( 255, 255, 255, 150 )
surface.DrawTexturedRect( 0, 0, self:GetWide()-36, 24 )
surface.SetTexture( self.texRating )
surface.SetDrawColor( 255, 255, 255, 255 )
surface.DrawTexturedRect( 20, 4, 16, 16 )
return true
The above code is my line(s) 42 to 88. I'm not sure if you tested this, but my version of the scoreboard has a "//if ( team.GetName(self.Player:Team() ) == Unassigned) then" line, about 4 lines down from line 42(the first line in code tags) That line is basically stating, if player not valid, set team to "Unassigned" which un-commenting that may fix the error, and may remove the gray label, in which you speak of.
« Last Edit: January 25, 2011, 09:15:29 pm by hymsan »
Offline norm555
Re: SUI Scoreboard
« Reply #8 on: February 23, 2011, 09:27:03 pm »
If you do want a working and on-buggy version of the SUI Scoreboard, i just downloaded it here: http://www.garrysmod.org/downloads/?a=view&id=66617
Offline hymsan
Re: SUI Scoreboard
« Reply #9 on: February 27, 2011, 10:23:45 am »
That was uploaded like 600 days ago, coming to the forums for a fix, which I did, has fixed the issue. Thanks.
