Author Topic: !menu doesn't run.  (Read 7595 times)
Offline kaskull
!menu doesn't run.
« on: March 08, 2011, 06:58:11 am »
Hi every one.
I've a little problem with Ulysses.
I've installed Ullysses, and i know taht it runs, because i've tried this command: "!jail kas"   And it runs ok.
But i want to use the menu because it's easyer.
Re: !menu doesn't run.
« Reply #1 on: March 08, 2011, 07:13:55 am »
What version of ULX are you running? Release or SVN?
Offline kaskull
« Reply #2 on: March 08, 2011, 07:37:41 am »
SVN
Offline krooks
  • I don't like video games.
    • Diamond Krooks
« Reply #3 on: March 08, 2011, 09:06:38 am »
You can also try !XGUI or bind a key to "XGUI".
My TTT server. Join the fun!
Offline kaskull
« Reply #4 on: March 08, 2011, 09:25:27 am »
It doesn't appear any thing.
But i've a little question, i don't know if it some thing relationated with Ulysses, but when i enter in my server, at the top on the right it apperars this:
Lua cache coudn't be downloadad. Server is misconfigured
Offline krooks
    • Diamond Krooks
« Reply #5 on: March 08, 2011, 10:13:16 am »
Thats your issue.
If you have fast downloads set up (sv_downloadurl "yourWebsite.com/gmodserver") in server.cfg you *must* upload the .dua file in garrysmod/cache to the mirrored fast dl server any time you make an addon change.
If you don't have a fast dl server, remove sv_downloadurl from your server.cfg and you should be alright.
« Reply #6 on: March 08, 2011, 02:52:00 pm »
Thats your issue.
Indeed. If you can't download the necessary client side files, which the menu runs on, only the server ones work (console commands, etc).
