Author Topic: Error when opening !menu  (Read 4235 times)
Offline UnknownTBeast
« on: April 01, 2011, 09:03:25 pm »
Figured this was not a real bug, so I'm posting here.
Just installed ULX 3.40/ULib 2.30, restarted the server, got the default motd, but when I type in !menu, I get the bellow error.
Not sure if I added myself as a user correctly since there doesn't seem to be any firm documentation that I could find that explains how to add users. Then I read that there are different users for ULX and ULib, and apparently you can't mix between the two. Then when I can find the slightest readme, it says add users to a file that doesn't exist in a non-existant folder under garrysmod/data/ULib/users.txt. I added myself to the group.txt file after creating the ULib folder under /data (as it was the only example on adding users.), and this is the error...(at bottom of post apparently)
I also had a while back added myself to the /settings/users.txt...but not sure if that's just for rcon or not.
Ideas?
Re: Error when opening !menu
« Reply #1 on: April 01, 2011, 09:25:02 pm »
At this point, it's a miracle that the release versions of ULib and ULX work at all. I know this conflicts with other information on the forums, but I'd recommend using SVN for now. We're pretty stable, we only have one more holdup before we release what's currently in SVN.
« Reply #2 on: April 01, 2011, 09:53:14 pm »
...well I got it working...it was , but it works now.
Still have no idea on what SVN or how it even works. That will be another trial.
« Reply #3 on: April 01, 2011, 09:54:36 pm »
Oh and this problem could had been avoided if I read this first...
/index.php/topic,383.0.html
...it's helpful!
« Reply #4 on: April 01, 2011, 10:00:44 pm »
Indeed.
You'll find that not only useful for our 'beta' but stable SVN code, but also several other popular Gmod releases.
Phoenix model pack, Wire model pack, several others use SVN only to distrubute.
