Author Topic: Can't pick up props  (Read 10021 times)
Offline drake90001
  • Formerly xXMyFateXx
Can't pick up props
« on: April 06, 2011, 03:28:36 pm »
So, recently, (By recently, I mean yesterday), I had a friend join, and I give him admin, using the command "ulx adduser "His Name" admin" (regular). He was abusing RIGHT away, so I did the command, "ulx removeuser "His Name", and everything was going fine. But then, (At this point he was a user), he was not able to pick up any props that he spawned. I figured it was because he had lost all access rights. I then tried it to a superadmin, removed his admin, and then the same thing happened. I did a full reinstall of the garrysmod portion of my server. I added URestrict, ULX (SVN), ulib (SVN), UPS (Which I am also having problems with). I joined after a full reinstall, without admin, and I can't pick up any props that I spawn. So if I can get some help, that would be great.
Thanks--
 Drake
Offline hymsan
Re: Can't pick up props
« Reply #1 on: April 06, 2011, 04:27:58 pm »
What other addons do you have installed? This doesn't sound like a ULX issue. Removeuser works perfectly fine on my server.
Offline drake90001
« Reply #2 on: April 06, 2011, 04:35:40 pm »
« Reply #3 on: April 06, 2011, 04:38:28 pm »
To my knowledge, URestrict doesn't work well anymore, and has been known to conflict with our later stuff.
Aaron hopes to get it up and going again since Jay left, but that may be some time off.
If you shutdown server, remove UPS, then start back up.. can you pick up props?
If so, look through the UPS thread for the SVN location, as the one from the first post may be buggy now.
If you can't, you have some other prop mod or part of the game mode you use causing problems.
Offline drake90001
« Reply #4 on: April 06, 2011, 04:45:57 pm »
Alright, I'll try without UPS.
And do you know any other way to keep regular players from spawning things from weapons or entites? Thanks (Excuse spelling, I'm really tired)
EDIT: Removing UPS seemed to fix it (also, when I'm in game, it says that it is not installed on the server, even though it is.). I'll check for the other SVN, but if someone might be able to post it for me, it would save time, because Internet Explore is slow on my server. Thanks ;)
EDIT 2: I just realized I was not using the SVN version of UPS. I had done a search for "ups svn", and found a post saying; "For anyone having problems picking up props, using the SVN version fixes it.". Sorry for not searching first. ;) I think I am all good now, thank you.
+karma to everyone
EDIT 3: Nope. UPS is dead. I guess I'll us FPP. The problem is I am in love with ULX ;)
« Last Edit: April 06, 2011, 07:01:44 pm by xXMyFateXx »
« Reply #5 on: April 06, 2011, 07:20:27 pm »
UPS SVN should work. It sounds as though you have some sort of conflicting mod.
As for restricting weapons/entities, sorry, no, not at this moment.
Give Aaron a bit more time to pick up Jay's project, or at least, come out with his own version.
Please post any errors regarding UPS in the UPS discussion.
After getting some rest, you may wish to read at least the few final pages of the UPS thread.
Last I knew, UPS SVN should work.
« Reply #6 on: April 06, 2011, 07:30:58 pm »
I'll get to work soon.  I may just release a wip version without any sort of menu.  I feel the menu may take a bit longer as I'm not very experienced with derma.
« Reply #7 on: April 06, 2011, 08:10:30 pm »
Take your time, and look into XGUi's page hooks/etc.
I asked Stickly Man to keep modding/addons in mind from the beginning.
I've not looked at the raw code yet, but am pretty sure he has.
Hopefully he's commented well too. If not, ask in dev corner, we'll all learn together. :)
