Author Topic: ULX: Permanent Bans not saving [Solved]  (Read 31918 times)
Offline Ceka
Re: ULX: Permanent Bans not saving
« Reply #15 on: April 11, 2011, 06:12:02 am »
Allright. Now im not really experted in this; but for simplicity sake; I think the case is closed and that il update ulx; seems to have a new version and it should be fixed right? If not il just edit this! :) thanks for the help. Btw if this is not what im suposta do a instructions.txt could give a hand xD
Offline edk141
« Reply #16 on: April 11, 2011, 06:17:30 am »
It should be fixed, please post again to confirm though as you're the only person who can actually test it
Offline Ceka
« Reply #17 on: April 11, 2011, 06:22:45 am »
Yes. It is Fixed, Il edit the title. Thank you alot, Ulx Team ^^
Re: ULX: Permanent Bans not saving [Solved]
« Reply #18 on: April 11, 2011, 09:41:33 am »
Are you absolutely certain this solved the problem, Ceka?
Offline Ceka
« Reply #19 on: April 11, 2011, 10:08:13 am »
Yes. I tested it even with DarkRP, with all addons. It is solved. I added a few bans; works very nicely
« Reply #20 on: April 11, 2011, 11:23:49 am »
Okay, thanks! :)
« Reply #21 on: April 11, 2011, 02:00:39 pm »
Still odd that it is only occasionally seen.
Offline edk141
« Reply #22 on: April 11, 2011, 03:04:31 pm »
Could it be that file.Read tries to convert line endings and doesn't always succeed?
« Reply #23 on: April 11, 2011, 06:37:00 pm »
Oh, absolutely.
Could be just about anything.
Trick is .. what?
I suspect a dodgy lua file somewhere, another mod most likely, doing it's own thing.
Meh, either way, thanks for the help in finding a fix, another mod or ours.
Offline [GODR] g_o_r_k_e_m
« Reply #24 on: January 26, 2016, 02:25:03 pm »
Just happened to my server too i was going to do a new post than i saw this since its rare i will have a backup of my current ulx / ulib files before uptading them and i will send it to you guys so u can investigate it if necessary
[if you guys would like the backups of the current version please contact via steam]
« Reply #25 on: January 26, 2016, 02:51:21 pm »
[GODR] g_o_r_k_e_m, please start a new thread in the help and support section of our forums.
Though your issue may be similar, this thread is 5+ years old, and many, many, MANY Gmod, Ulib, and ULX version updates have occurred since.
The root cause of your issue is likely not to be the same.
« Reply #26 on: January 26, 2016, 03:16:14 pm »
the problem is its the exact same problem and its an old version of ulx / ulib im uptading them currently
quick question > i forgat where bans where saved
« Reply #27 on: January 26, 2016, 03:24:15 pm »
We no longer support versions of ULib/ULX from 5 years ago.
Why are you running a version that old?
gmod/data/ulib/ and gmod/data/ulx
