Author Topic: XGUI not communicating with server?  (Read 18741 times)
Offline ForceGhost
Re: XGUI not communicating with server?
« Reply #15 on: December 04, 2011, 02:09:37 am »
IVe got the exact same problem and am missing a couple of tabs in my XGUI, How did you guys resolve it?
« Reply #16 on: December 04, 2011, 11:19:50 am »
Just so everyone else knows, the problem was being caused by an older version of ULX being installed in a different location on the server (in his case, directly inside the garrysmod folder)
Basically, make sure you have latest SVN version, installed properly on the server, of both ULX and ULib.
Make sure you don't have old copies installed elsewhere on your server.
Make sure your server is sending files to the client.
Make sure your client is downloading, and running the proper files.
Offline ForceGhost
« Reply #17 on: December 05, 2011, 01:05:07 am »
All of those are fine as far as i can see, Any chance you could help me on steam?
« Reply #18 on: December 06, 2011, 09:25:05 am »
Post your server console log when you start a map, there are probably some errors during startup causing this.
