Author Topic: Reset ULX To stock values  (Read 16262 times)
Offline Weapon317
« on: April 28, 2011, 05:12:57 pm »
Hey guys, Ok I messed something up in ULX I made groups higher then Superadmin, that was no problem but I wanted to play around with commands I resticted something "ulx groupallow" if im correct, I tried reinstalling ULX complete but for some reason it holds all the old config, Heres the question: Can I Reinstall ULX completely and start over witout holding anything? Just a fresh instal, and yes witout reinstalling my server. Also if thats not a option, whats the rcon command? "rcon ulx allowuser [name] ulx groupallow" I tried, dint worked out well, useing SVN Sticky man GUI.
Thanks!
Re: Reset ULX To stock values
« Reply #1 on: April 28, 2011, 05:25:51 pm »
To do a "fresh install", simply delete your servers' garrysmod\data\ulx and garrysmod\data\ulib folders.
If you just want to give access back to groupallow to superadmins, you can run this command:
rcon ulx groupallow superadmin "ulx groupallow"
Offline Weapon317
« Reply #2 on: April 28, 2011, 05:40:27 pm »
Ah data map, Dint looked in there just deleted at addons folder, Thanks for the fast response much appriciated ^^
« Reply #3 on: April 28, 2011, 05:49:46 pm »
Welcome
Offline Weapon317
« Reply #4 on: April 28, 2011, 06:22:56 pm »
Sorry but I have only 1 more question, after I did that rcon ulx groupallow thing this error pops up everytime people conenct to the server
[@lua\includes\extensions\table.lua:55] bad argument #1 to 'pairs' (table expected, got nil)
Is this something from ULX?
Also how would I disable the MOTD on my server, that it doesnt popup when you enter the server, I had a awesome MOTD but forgot to backup it with reinstall.. :l So I want it disabeld untill I made a new one.
Thanks! ^^
« Reply #5 on: April 28, 2011, 08:00:28 pm »
What is that 'thing' you keep referring to? What exactly are you typing, how are you typing it?
You mention XGUI..are you running SVN of ULX and ULib? If so, why aren't you using XGUI to edit your groups?
Though that particular error isn't ULX, it does have potential to be caused by ULX if you edit a file wrong, or input a command wrong.
As for ULX motd, you can look in your data/ulx folder for configs. One of the config files has a ulx showmotd you can change.
For Source server itself, I believe you can set motdfile to ""
Offline Weapon317
« Reply #6 on: April 29, 2011, 04:17:50 am »
Because I typed this "rcon ulx allowgroup [name]" And since you said "it does have potential to be caused by ULX if you edit a file wrong, or input a command wrong." It might be that, I was in a rush actually because there were people on the server and now ULX is a bit messed up because of me. Anyways Yes I use the SVN and I did used the XGUI itself for editing commands. I just disabeld the wrong command. Also I made groups higher then Superadmin what turned out good only I thought "let me disable ulx adduser, ulx addgroup, ulx userallow etc. for superadmins, they dont need it and if someone needs it ill use rcon" but that dint turned out well. Is there a way to slove this error? "[@lua\includes\extensions\table.lua:55] bad argument #1 to 'pairs' (table expected, got nil)"
And for the Motd, thanks I got that fixed now.
Edit: I removed ULX again and the error was gone, when I put it back, fresh instal deleted everything from the data folder and from addons, and redownloaded it from this website, it comes again?
« Last Edit: April 29, 2011, 04:56:27 am by Weapon317 »
« Reply #7 on: April 29, 2011, 07:14:19 am »
That command properly doesn't work for me on my server:
Invalid command entered. If you need help, please type "ulx help" in your console.
As far as your error, post your FULL context around the error (if during startup, post the full startup log).
Offline Weapon317
« Reply #8 on: April 29, 2011, 07:36:16 am »
Welcome to  {>BW<} 24/7 {UK} Trouble in Terrorist Town Modded #1  | Fast DL |! We're playing ttt_vessel.
{>BW<} PedoBear entered the server, their SteamID is: STEAM_0:0:27682564
RunConsoleCommand blocked - sent before player spawned (_xgui)
ULX version <SVN> revision 165 loaded.
CMaterial::PrecacheVars: error loading vmt file for maps/dm_richland/glass/glasswindowbreak070b_0_2_91
TTT Client post-init...
Player [1][{>BW<} PedoBear]   authed
test   true
//  ULX GUI -- Made by Stickly Man!  //
// Loading GUI Modules...            //
//   bans.lua                        //
//   commands.lua                    //
//   groups.lua                      //
//   maps.lua                        //
//   settings.lua                    //
// Loading Setting Modules...        //
//   server.lua                      //
//   xgui.lua                        //
// Loading Gamemode Module(s)...     //
//   No module found!                //
// Modules Loaded!                   //
Redownloading all lightmaps
TTT:   Your Karma is 1000, so you deal full damage this round!
TTT:   A new round begins in 60 seconds. Prepare yourself.
Round state: 2
Server-cvar 'sv_tags' is gewijzigd in garrysmod120,gm
Server default language is:   english
« Reply #9 on: April 29, 2011, 08:41:23 am »
Doesn't look like that's an error from ULX. Everything in ULX and XGUI is working properly for you?
Offline Weapon317
« Reply #10 on: April 29, 2011, 08:53:27 am »
When adding groups or commands to groups the error pops up, and when entering the server.
« Reply #11 on: April 29, 2011, 09:03:50 am »
The same error or a different error? Do the commands still work?
Offline Weapon317
« Reply #12 on: April 29, 2011, 11:18:41 am »
Commands work, groups etc. works its just annoying that when adding groups or commands the same error pops up in yellow at the right side of the screen
