I've been working on this project slowly and decided just to release a Beta that I would build off of.  URS is an acronym and stands for Ultimate Restriction Suite.  This project is a replacement of URestrict, which development was sadly stopped on.  I decided to develop this after URestrict just suddenly stopped working one day on my server and I had absolutely no restrictions.  Then Jay announced that he would not be able to continue development on it, and so I decided I'd take up a project of my own.  I'm not the most experienced in the field of Lua, but I certainly can get the job done (hopefully I do a decent job).
Features:
  • Fully functional menu IN XGUI!!
  • Restrictions for:  Props, Tools, Sweps, Sents, Vehicles, Ragdolls, Effects, Advance Duplicator, Pickups (weapons), and NPCs.
  • Custom Limits for:  Vehicles, Effects, Npcs, Ragdolls, Props, and Sents.
  • Custom Loadouts for each and every group.
  • Tool Usage Logging
  • Auto-Saving, never lose your changes!
  • Decide if your changes are public or not!
  • Restrict everything of a given type at once!
  • Does not tamper with Prop Protections or other scripts!
Please see our Wiki page for additional help!
https://github.com/Aaron113/URS/wiki
NOTE: Requires version 3.50+ of ULX
(Workshop is most likely to be out of date)
Need Help?  SVN Guide
« Last Edit: May 27, 2016, 06:02:11 pm by JamminR »
« Reply #1 on: May 09, 2011, 09:18:07 pm »
I think you have a great idea going there, but I hope you have a menu soon because 70% of my admins cant use stuff like this without a menu (no offence any admins that are reading this). I also would like to offer some help, because I am just starting to code LUA and this is a great opportunity to learn. In addition if its not too much of a struggle I was wondering if you could integrate the restrictions with SQL.
« Reply #2 on: May 09, 2011, 09:27:15 pm »
Looking good!
« Reply #3 on: May 10, 2011, 05:14:37 am »
I could probably get something in for SQL, but the menu and some other additions I have planned come first.
« Reply #4 on: May 10, 2011, 08:17:42 am »
Very nice.
Offline krooks
  • I don't like video games.
    • Diamond Krooks
« Reply #5 on: May 10, 2011, 09:22:22 am »
Awesome! Glad you've found some time to work on this.
I'll be installing it as soon as I find a little time myself  ;D
My TTT server. Join the fun!
« Reply #6 on: May 10, 2011, 01:52:20 pm »
I'd just like to note, I haven't tested this much at all in a dedicated server.  I shut mine down, so I'll have to get one up to test.  Otherwise, any feedback on how it's working in dedicated servers is welcome.
EDIT:  I also added a little Features list.
EDIT2:  I just organized and decorated the OP even more.
« Last Edit: May 10, 2011, 02:20:54 pm by Aaron113 »
« Reply #7 on: May 10, 2011, 02:09:45 pm »
Not URS!
Oh, wait, it IS URS.
Nice!
« Reply #8 on: May 10, 2011, 05:30:35 pm »
Added the command ulx print [limits/restrictions/loadouts] to make up for not having a menu yet.  This prints the tables for loadouts, limits, or restrictions into your console.  See better description in OP.
Also, thanks for the compliments.
« Last Edit: May 11, 2011, 05:10:37 am by Aaron113 »
« Reply #9 on: May 10, 2011, 08:21:10 pm »
Aaron, I was looking over your code and just wanted to point out that ULX function call backs are only called server-side, so putting "if SERVER then ... end" is unnecessary.  And calling GetConVarNumber() is pretty inefficient because the engine has to lookup the cvar object in a linked list each time, it'd be better to store the cvar object and get the number directly from it.
Hope you find these suggestions helpful. :)
« Reply #10 on: May 11, 2011, 04:29:44 am »
Thanks, both will be changed.
EDIT:  Done as of 5/11/11.
« Last Edit: May 11, 2011, 02:36:09 pm by Aaron113 »
« Reply #11 on: May 12, 2011, 01:30:06 pm »
You can still make convar changes have instant effect, I was just recommending using ConVar:GetBool() instead of using the global function (which incurs a lookup). :P
« Reply #12 on: May 13, 2011, 11:37:26 am »
Hehe, I'll be changing it in rv5.  :-[
Also, is there a way to have the completes for a command updated?  I know XGUI uses something for ban and kick reasons, but rather then looking through several files I thought I'd just ask.  Stickly is going to help later, but feel free to explain if you want.
« Last Edit: May 13, 2011, 12:25:54 pm by Aaron113 »
« Reply #13 on: May 13, 2011, 12:44:03 pm »
You just update the table that has the completes you want. Make sure you don't try to "clear" the table first by doing "my_var = {}" because that creates a new table that is no longer tracked by ULX. (This is a Lua language thing, if you want me to go more in depth I can)
« Reply #14 on: May 13, 2011, 01:59:22 pm »
I swear I've tried that before and it didn't update.  Anyway, I'll try it out later and get back to you.
