Author Topic: Respected Rank  (Read 7578 times)
Offline TropicalTitties
Respected Rank
« on: May 10, 2011, 06:32:02 pm »
How would i make it so that people would have to have a certain rank, such as respected (or above), in order to become a class, such as swat? However, the respected rank would not have admin privileges, just the ability to become swat and other respected rank.
Would I use a function, such as:
function GM:PlayerJoinTeam( ply, class, teamid )
if ply:IsUserGroup("User") and teamid == TEAM_SWAT then
return false
return true
Or something else?
I honestly cant figure out what else to try.
EDIT-JamminR Added code block
« Last Edit: May 10, 2011, 07:18:40 pm by JamminR »
Re: Respected Rank
« Reply #1 on: May 10, 2011, 07:32:12 pm »
Way you have it is the basic idea, but, you need to use lower case when comparing groups. "user" not "User"
A better way to do it, since some groups inherit lower ones, is probably test for the "respected" specifically.
Also, in 99% of Gmod lua, when you wish a hook function to continue, don't return "true", just return.
There are exceptions, but, returning anything will often break the hooks of other mods/scripts using the same hook, even if it is only 'true'
(Yes, I know, the Gmod wiki is full of 'return true'...many hooks break others that way.
if not ply:IsUserGroup("respected") and teamid == TEAM_SWAT then
return false
return
In english, the above statement reads
if player is not in group respected and they want to join Swat team, do nothing, else if they are in group respected and want to join swat, go ahead.
Re: Respected Rank
« Reply #2 on: May 10, 2011, 08:29:26 pm »
In this situation he would want to use return true.
If you are calling a function and expecting a boolean value then returning true/false in that function is appropriate. It's generally okay to return true unless you are using it in a hook (like JamminR said).
for example:::
  1.
  2. function TestFunction()
  3.     if IsATree( entity ) then
  4.         Print("This is a Tree")
  5.     else
  6.         Print("This is NOT a Tree")
  7.     end
  8. end
  9.
  10. function IsATree( entity )
  11.     if entity:GetModel() == "models/props/tree.mdl" then
  12.         return true
  13.     else
  14.         return false
  15.     end
  16. end
  17.
  18.
It's kind of rough.. some of it's pseudo(ish) code...
« Last Edit: May 10, 2011, 08:36:08 pm by MrPresident »
Re: Respected Rank
« Reply #3 on: May 10, 2011, 09:15:12 pm »
But, with GM:<function> being a gamemode hook, wouldn't he NOT want to return anything if he wanted all other scripts calling it to continue, including whatever game uses a "Swat" team?
I really am ignorant and out of practice, and to be honest, never have fully understood where to allow it when it comes to Gmod.
I understand YOUR (mrP) code perfectly, and know a boolean is expected.
But I thought that Gmod expects no boolean values unless false though, and breaks stuff if one is received even when true.
Re: Respected Rank
« Reply #4 on: May 11, 2011, 05:45:29 am »
Thanks guys, and Jammin i understand your code perfectly and it should work, although it doesnt. Ive tried using both return true and return.
however neither of these seem to work and normal users can still become the SWAT . I used the exact code that jammin used, with and without the true after return.
return false
return true
« Last Edit: May 11, 2011, 05:49:53 am by TropicalTitties »
Re: Respected Rank
« Reply #5 on: May 11, 2011, 01:54:50 pm »
Where is this code being added?
Re: Respected Rank
« Reply #6 on: May 11, 2011, 02:14:11 pm »
gamemodes/DarkRP/gamemode/sv_gamemode_functions.lua
Re: Respected Rank
« Reply #7 on: May 11, 2011, 06:59:55 pm »
Are you sure that this gamemode doesn't already have a PlayerJoinTeam function?
Re: Respected Rank
« Reply #8 on: May 11, 2011, 07:22:28 pm »
Gamemode.PlayerJoinTeam
According to this you have the arguments in the function wrong.
Re: Respected Rank
« Reply #9 on: May 11, 2011, 07:26:40 pm »
So it would be
function GM:PlayerJoinTeam( ply, teamid )
return false
return true
