Author Topic: ULX 3.51 / ULIB 2.40 Fresh Install --> unauthed Player  (Read 5115 times)
Offline SkyRanger
« on: May 23, 2011, 02:24:46 pm »
Hi there
I just installes ULX / ULIB from latest Versions
and i made me throught RCON with "ulx adduser ...... superuser" to Admin.
Ingame i got an messagt, that the Console added me to superuser.
but i still get an small window, which tells me, i should wait a few seconds to auth my Player.
but even after 1 hour i get same error.
i reinstalled few times, even the whole dedicated server, but it still wont work.
why ?
Re: ULX 3.51 / ULIB 2.40 Fresh Install --> unauthed Player
« Reply #1 on: May 23, 2011, 04:07:18 pm »
Please provide your server console start up log.
The Server console log of when you join your server, after you've used rcon to add yourself as superadmin (Not superuser)
The game console log of when you join your server, and the file output from your server when you use "ulx debuginfo" in the rcon.
As for the window you mentioin 'authing player'... is that after you've run a command? Or joined your server?
(Stick, other than if he ran Xgui and got that message (1. Would he?), 2) Would there be anywhere else he'd get it from xgui)
Additionally, you may wish to
1) Clean your local gamecache folder.
2) verify you've cleaned out your local game /addons/ulx and /addons/ulib folders. I've seen some odd issues with having much older code.
« Last Edit: May 23, 2011, 04:09:02 pm by JamminR »
« Reply #2 on: May 23, 2011, 06:38:46 pm »
It is an error that occurs when you try to open XGUI-- the technical details is that ULib.ucl.authed[LocalPlayer():UniqueID()] does not exist.
This can only be caused by a few things that I can think of. Along with trying what JamminR suggested, try doing these steps until it works:
1) Older version of ULX installed on your client.
          Make sure you don't have a copy of ulx/ulib installed in your /steamapps/<username>/garrysmod/garrysmod/addons/ folder. (Or make sure it's updated)
2) Older version of ULX/ULib installed alongside the new release version
          Maybe you have an older version in the addons folder, or an older one that was installed directly into the garrysmod folder.
3) Conflicting addon
          You said you reinstalled the server-- but did you delete/move ALL of the server files, let it redownload itself, then try installing ONLY ULX/ULib before you added other addons? (Also run it in sandbox, just to be safe)
