Author Topic: mblunk's list of suggestions  (Read 10456 times)
Offline mblunk
« on: November 16, 2006, 12:24:19 pm »
One night, when I had nothing to do, I came up with a list of things I'd like to see in ULX.
The commands I'd like to see are:
  • cloak <player>  -- Make a player invisible by changing their alpha to 0 for true invisibility.
  • uncloak <player>  -- Uncloak a person cloaked by the cloak command.
  • playermodel <player> <model>  -- Change the playermodel of the specified player.
  • giveswep <player> <SWEP filename>  -- Give the specified player a certain SWEP
  • stripweps <player>  -- Removes ALL weapons from a player, including the toolgun
  • mute <player> <time>  -- Sometimes, gimp spam can get annyoing. Use this to make them STFU.
  • jail <player> <time>  -- Spawn four jail walls around a player, make them static and remove them after the specified time.
  • ragdoll <player> <time>  -- Turns a player into a ragdoll for the specified time
  • propcount <player>  -- Will count the number of props/vehicles/ragdolls etc someone has spawned and print it in the console
  • notify "<message>" <time>  -- Creates a box with a certain message that is meant to last longer amounts of time that contains a basic reminder to people, such as "mblunk is the admin" and other things you want players to keep in mind.
Settings that go in the config INI that should be:
  • Curse word blocker, complete with an editable blocked words list
  • Spawn time, that sets how quickly a person can spawn props (like the spawn timer on the SWEP menu)
  • Prop protector, where player's physguns and tools only affect their own props
  • Deathmatch counter, where you can enable a counter that will count how many times a player kills someone then after an editable amount of kills has been reached, a proper punishment will be administered
  • Ping kicker setting, where every __ minutes or whenever a ping goes above __, the player with the highest ping will be kicked (won't affect admins)
And everything else:
  • Rule presets: it should come with a set of CFG files that will automatically set the rules to accomodate the type of server you are going to run then can be executed through the ULX menu
  • Some extra menu themes and skins, so you can make ULX's menu look nicer according to your personal taste
  • SWEP access list, where when a certain player has a certain access flag they can use all of the SWEPs on a pre-set admin-only list defined in the INI config, but if the player doesn't have that flag they will be sslayed when they pick up a SWEP on the admin-only list
  • Color arguments to csay
That's it for now, thank you for reading.
I have too much free time.
« Last Edit: November 20, 2006, 01:44:34 pm by mblunk »
Re: mblunk's list of suggestions
« Reply #1 on: November 16, 2006, 01:02:57 pm »
Hey, those are some great ideas! I especially like your ragdoll idea, very creative. :)
Offline Golden-Death
  • Honored Lua Scripter
    • BlueFire
« Reply #2 on: November 16, 2006, 10:04:36 pm »
# giveswep <player> <SWEP filename>  -- Give the specified player a certain SWEP
# stripweps <player>  -- Removes ALL weapons from a player, including the toolgun
You can give SWEPS with my Script Manager plugin and you can strip all weapons with my "GD Pack" plugin. The other ideas are great though.  ;)
« Reply #3 on: November 24, 2006, 03:57:14 pm »
mblunk, saw you join my server earlier today. You mentioned suggestions, stood in front of me while I was trying to weld something. I told you to 'move'.
You left before I got a chance to ask what you had said.
Some of your ideas are being implimented.
I can't say that they are being implimented due to your suggestion, but, I can't say they aren't either.
    * cloak <player>
    * uncloak <player> --  Megiddo is working on a !invisible # and !uninvisible. # will be an alpha level.
    * playermodel <player> <model>  -- I THINK I saw him working on this.
    * giveswep <player> <SWEP filename> -- SPBogie has written USwep in releases,
    * stripweps <player>  -- SPBogie has written USwep in releases, and Megiddo is working on a way to enable/disable toolguns. Perhaps he'll incorporate this too.
    * mute <player> <time>  -- Status unknown
    * jail <player> <time>  -- Status Unknown - I've seen a Swep that does this though. Doubtful it would be added to ULX or ULib
    * ragdoll <player> <time>  -- I've seen Megiddo working with this.
    * propcount <player>  -- I've seen Megiddo working on this. Megiddo was running into a Gmod lua challenge, that is, a lua binding that appeared incomplete.
    * notify "<message>" <time>  -- Status unknown. Personaly, I doubt it. advert and Cadvert can be used, even if not held for a variable amount of time. most recent release of ULib did include consecutive timer capability though. I'm not sure its used yet.
    * Curse word blocker, -- Status Unknown. I've seen Megiddo speak of such code, though, I believe it would be a module release more so than an addition to ULX directly.
    * Spawn time, that sets how quickly a person can spawn props
    * Prop protector, where player's physguns and tools only affect their own props -- Status unknown - Though, we are working with a scaled down propprotector. Would have a new access level, and would only protect those you added, much like the old prop protector in ULX v1 (but this one would WORK 99% of the time) :P
    * Deathmatch counter -- Status unknown
    * Ping kicker setting,  -- Status Unknown
    * Rule presets: it should come with a set of CFG files that will automatically set the rules to accomodate the type of server you are going to run then can be executed through the ULX menu -- Already included in ULX 2.21 - build.cfg and deathmatch.cfg .. can be executed in game, or, set in the <mapname.ini> to execute on certain maps. ACTUALLY, ulx exec has been in ULX for quite a while, we've just never included .cfg files before.
    * Some extra menu themes and skins, so you can make ULX's menu look nicer according to your personal taste -- We are Borg of ULX. You will be assimilated. All joking aside, the menu system is modular. Just have to know where to edit the code.
*(I could be wrong on this, it was _meant_ to be modular, but Megiddo/Spbogie have been discussing menu redesign)
    * SWEP access list -- See SPBogie's USwep. Won't slay, but has different access levels, and more can be added.
    * Color arguments to csay-- Status unknown
« Reply #4 on: November 24, 2006, 08:16:43 pm »
Wow JamminR, that must've taken some time. :)
You're pretty much right on all, but I thought I'd clarify some:
cloak/uncloak - Finished, working 100%
playermodel - Wasn't really planning on it, and if I did, you'd choose from a menu of available models... to much risk of a crash.
mute - Finished, working 100%
jail - 50%, will be in next ULX most likely
ragdoll - 90%, still wants to crash the server sometimes
propcount - I saw a lua interface that looks like it was supposed to do this, but alas, it doesn't function properly. Not likely to be in next ULX.
curse blocker - Every time I start working on it, I realize what an immense project it would be without the full regex library and drop it.
BODYPRINT
« Reply #5 on: December 04, 2006, 06:49:48 am »
Could you add more options to the clean command to remove Dynamite?
Also if you could add a cleanup on the client menu would be great as well. That way you can cleanup 1 persons crap without destroying everybody elses stuff.
I also have a sort of related question, is there a console command to remove your stuff, so I can do a cexec command to cleanup peoples rubbish?
Cheers, and keep up the great work !!
Offline Terminal58
« Reply #6 on: December 13, 2006, 07:58:11 pm »
String.replace tires me out too. *giggle*
Go look up your 500 swear words NUB!@!
Ham is offensive to the Muslim religion.
