Author Topic: Help with a lua  (Read 11269 times)
Offline killforfun
Help with a lua
« on: June 16, 2011, 09:30:51 am »
What it should do is when i type !minge (players name) in chat it should add that person to the ulx group minge
This will not work and i cant find it to enable it for superadmins
made by JusticeInACan
// save this as minge.lua in the folder garrysmod/garrysmod/addons/ulx/lua/ulx/modules/sh/ and give the ulx minge right to yourself
local CATEGORY_NAME = "User Management"
local function ulx.mingeuser(ply,target)
ulx.adduser(ply,target,"minge")
local mingeuser = ulx.command( CATEGORY_NAME, "ulx minge", ulx.mingeuser )
mingeuser:addParam{ type=ULib.cmds.PlayerArg }
mingeuser:defaultAccess( ULib.ACCESS_SUPERADMIN )
mingeuser:help("Turn a user into a minge." )
« Last Edit: June 16, 2011, 02:52:58 pm by killforfun »
Re: Help with a lua
« Reply #1 on: June 16, 2011, 01:27:55 pm »
Give us more details than "it doesn't work". Are there errors in the client or server console?
Offline killforfun
Re: Help with a lua
« Reply #2 on: June 16, 2011, 01:57:15 pm »
this is all that's in my console from start up
memode 'sandbox' derived from 'base'
--- Missing Vgui material texturemissing
Sending 1339 'User Info' ConVars to server (cl_spewuserinfoconvars to see)
Scanning for downloaded fonts..
Reloading Particles..
unrecognized conditional test GPU<2?$STARTFADESIZE in particle/vistasmokev1_min_depth_nearcull
unrecognized conditional test GPU<2?$ENDFADESIZE in particle/vistasmokev1_min_depth_nearcull
unrecognized conditional test GPU<2?$BLENDFRAMES in particle/vistasmokev1_min_depth_nearcull
unrecognized conditional test GPU<2?$DEPTHBLEND in particle/vistasmokev1_min_depth_nearcull
unrecognized conditional test GPU<2?$BLENDFRAMES in particle/spray1/spray1_streak
unrecognized conditional test GPU<2?$DEPTHBLEND in particle/spray1/spray1_streak
unrecognized conditional test GPU<2?$STARTFADESIZE in particle/vistasmokev1_add_nearcull
unrecognized conditional test GPU<2?$ENDFADESIZE in particle/vistasmokev1_add_nearcull
unrecognized conditional test GPU<2?$BLENDFRAMES in particle/vistasmokev1_add_nearcull
unrecognized conditional test GPU<2?$DEPTHBLEND in particle/vistasmokev1_add_nearcull
unrecognized conditional test GPU<2?$BLENDFRAMES in particle/vistasmokev1/vistasmokev1_fire2
unrecognized conditional test GPU<2?$DEPTHBLEND in particle/vistasmokev1/vistasmokev1_fire2
unrecognized conditional test GPU<2?$STARTFADESIZE in particle/vistasmokev1/vistasmokev4_nearcull
unrecognized conditional test GPU<2?$ENDFADESIZE in particle/vistasmokev1/vistasmokev4_nearcull
unrecognized conditional test GPU<2?$BLENDFRAMES in particle/vistasmokev1/vistasmokev4_nearcull
unrecognized conditional test GPU<2?$DEPTHBLEND in particle/vistasmokev1/vistasmokev4_nearcull
unrecognized conditional test GPU<2?$STARTFADESIZE in particle/vistasmokev1/vistasmokev4_addself_nearcull
unrecognized conditional test GPU<2?$ENDFADESIZE in particle/vistasmokev1/vistasmokev4_addself_nearcull
unrecognized conditional test GPU<2?$BLENDFRAMES in particle/vistasmokev1/vistasmokev4_addself_nearcull
unrecognized conditional test GPU<2?$DEPTHBLEND in particle/vistasmokev1/vistasmokev4_addself_nearcull
unrecognized conditional test GPU<2?$BLENDFRAMES in particle/spray1/spray1_addself
unrecognized conditional test GPU<2?$DEPTHBLEND in particle/spray1/spray1_addself
unrecognized conditional test GPU<2?$STARTFADESIZE in particle/vistasmokev1_fog_add
unrecognized conditional test GPU<2?$ENDFADESIZE in particle/vistasmokev1_fog_add
unrecognized conditional test GPU<2?$BLENDFRAMES in particle/vistasmokev1_fog_add
unrecognized conditional test GPU<2?$DEPTHBLEND in particle/vistasmokev1_fog_add
Client "[?l?l?]kill for fun" spawned in server (74.182.177.26:58717)<STEAM_0:0:15674006>.
Welcome to Spektrum|build|24/7| ! We're playing gm_construct.
[UTime]Welcome back [?l?l?]kill for fun, you last played on this server 06/16/11 14:36:55
Physgun build mode is available on this server
PlayX DEBUG: JW URL set
PlayX DEBUG: Host URL set
[ThreeD] Starting...
PlayX DEBUG: Providers list received
ULX version <SVN> revision 14 loaded.
RunConsoleCommand blocked - sent before player spawned (ZLib_Installed)
//  ULX GUI -- Made by Stickly Man!  //
// Loading GUI Modules...            //
//   bans.lua                        //
//   commands.lua                    //
//   groups.lua                      //
//   maps.lua                        //
//   settings.lua                    //
// Loading Setting Modules...        //
//   client.lua                      //
//   cl_apromote.lua                 //
//   server.lua                      //
// Loading Gamemode Module(s)...     //
//   sandbox.lua                     //
// Modules Loaded!                   //
Redownloading all lightmaps
Error Vertex File for 'Holograms/plane.mdl' checksum 647644133 should be -1495644899
Unknown command: resize_allow
I
and nun of it seems to be a error
Re: Help with a lua
« Reply #3 on: June 16, 2011, 02:29:51 pm »
I don't see you trying to use the command in there, and I'm assuming this output is from your client.
Also, where are you putting this file?
Offline killforfun
Re: Help with a lua
« Reply #4 on: June 16, 2011, 02:51:02 pm »
I'm saving it  as minge.lua in the folder garrysmod/garrysmod/addons/ulx/lua/ulx/modules/sh/
in my server files
also a had typo on the information above
 it should at that person to the ulx group minge
"should say"
 it should add* that person to the ulx group minge
Re: Help with a lua
« Reply #5 on: June 16, 2011, 03:41:19 pm »
Again, I don't see you attempting to use the command.
Offline killforfun
Re: Help with a lua
« Reply #6 on: June 16, 2011, 04:45:08 pm »
all i get when i type !minge Bot01 in chat is
killforfun: !minge Bot01
and when i type ulx mine in consol nothing shows up just unknown command
Re: Help with a lua
« Reply #7 on: June 16, 2011, 05:49:43 pm »
Show us your server console log from startup
Offline killforfun
Re: Help with a lua
« Reply #8 on: June 16, 2011, 09:01:37 pm »
Here are my lua errors that was loged in my garrysmod/garrysmod/logs/l0616003.log
and some of them are talking about the minge.lua file
L 06/16/2011 - 22:49:22: Lua Error: Couldn't include file 'includes\enum\act.lua' (File not found) (<nowhere>)
L 06/16/2011 - 22:49:22: Lua Error: Couldn't include file 'includes\enum\ai_caps.lua' (File not found) (<nowhere>)
L 06/16/2011 - 22:49:22: Lua Error: Couldn't include file 'includes\enum\ai_schedule.lua' (File not found) (<nowhere>)
L 06/16/2011 - 22:49:22: Lua Error: Couldn't include file 'includes\enum\collision_group.lua' (File not found) (<nowhere>)
L 06/16/2011 - 22:49:22: Lua Error: Couldn't include file 'includes\enum\contents.lua' (File not found) (<nowhere>)
L 06/16/2011 - 22:49:22: Lua Error: Couldn't include file 'includes\enum\cvar.lua' (File not found) (<nowhere>)
L 06/16/2011 - 22:49:22: Lua Error: Couldn't include file 'includes\enum\disposition.lua' (File not found) (<nowhere>)
L 06/16/2011 - 22:49:22: Lua Error: Couldn't include file 'includes\enum\dmg_type.lua' (File not found) (<nowhere>)
L 06/16/2011 - 22:49:22: Lua Error: Couldn't include file 'includes\enum\hitgroup.lua' (File not found) (<nowhere>)
L 06/16/2011 - 22:49:22: Lua Error: Couldn't include file 'includes\enum\hull_types.lua' (File not found) (<nowhere>)
L 06/16/2011 - 22:49:22: Lua Error: Couldn't include file 'includes\enum\keys.lua' (File not found) (<nowhere>)
L 06/16/2011 - 22:49:22: Lua Error: Couldn't include file 'includes\enum\mask.lua' (File not found) (<nowhere>)
L 06/16/2011 - 22:49:22: Lua Error: Couldn't include file 'includes\enum\mousecode.lua' (File not found) (<nowhere>)
L 06/16/2011 - 22:49:22: Lua Error: Couldn't include file 'includes\enum\movecollide.lua' (File not found) (<nowhere>)
L 06/16/2011 - 22:49:22: Lua Error: Couldn't include file 'includes\enum\movetype.lua' (File not found) (<nowhere>)
L 06/16/2011 - 22:49:22: Lua Error: Couldn't include file 'includes\enum\npc_state.lua' (File not found) (<nowhere>)
L 06/16/2011 - 22:49:22: Lua Error: Couldn't include file 'includes\enum\obs_mode.lua' (File not found) (<nowhere>)
L 06/16/2011 - 22:49:22: Lua Error: Couldn't include file 'includes\enum\player_anim.lua' (File not found) (<nowhere>)
L 06/16/2011 - 22:49:22: Lua Error: Couldn't include file 'includes\enum\solid.lua' (File not found) (<nowhere>)
L 06/16/2011 - 22:49:22: Lua Error: [addons\steeringwheelpack\lua\autorun\steeringwheelpack.lua:1] ')' expected near '.'
L 06/16/2011 - 22:49:23: Lua Error: [addons\ulx\lua\ulx\modules\sh\minge.lua:5] '(' expected near '.'
L 06/16/2011 - 22:49:23: Lua Error: [addons\ulx\lua\ulx\init.lua:50] ERROR PARSING CLIENTSIDE FILE: 'ulx\modules\sh\minge.lua'
L 06/16/2011 - 22:49:24: Lua Error: [addons\wiresocketrad\lua\includes\modules\socket.lua:14] attempt to call global 'Socket' (a nil value)
L 06/16/2011 - 22:49:24: Load Gamemode: 'sandbox'
L 06/16/2011 - 22:49:29: Lua Error: Skipping E2 extension 'holoanim'.
L 06/16/2011 - 22:49:29: Lua Error: Skipping E2 extension 'propcore'.
L 06/16/2011 - 22:49:29: Lua Error: Skipping E2 extension 'tracesystem'.
L 06/16/2011 - 22:49:32: server_cvar: "sv_tags" "PAC2"
L 06/16/2011 - 22:49:32: server_cvar: "sv_tags" "wsr"
L 06/16/2011 - 22:49:34: server_cvar: "sv_tags" "gm:sandbox,wsr"
L 06/16/2011 - 22:49:34: server_cvar: "sv_tags" "garrysmod124,gm:sandbox,wsr"
L 06/16/2011 - 22:49:34: server_cvar: "sv_tags" "alltalk,garrysmod124,gm:sandbox,wsr"
L 06/16/2011 - 22:49:34: Lua Error: [addons\wire\lua\entities\gmod_wire_expression2\core\e2lib.lua:445] attempt to call method 'PrintMessage' (a nil value)
L 06/16/2011 - 22:49:34: Log file closed
To make it easier for ya these are the ones talking about the file minge.lua
Re: Help with a lua
« Reply #9 on: June 16, 2011, 09:06:23 pm »
Without even looking at your log:
function ulx.mingeuser( ply,target )
Your function cannot be local.
Offline killforfun
Re: Help with a lua
« Reply #10 on: June 16, 2011, 11:23:57 pm »
yup this worked "but"
it showed up in the ulx menu and worked but i cant use command !minge (player)
Re: Help with a lua
« Reply #11 on: June 17, 2011, 04:19:11 am »
Show us your server/client logs again.
Re: Help with a lua
« Reply #12 on: June 17, 2011, 10:26:07 am »
function ulx.mingeuser( ply, target )
ulx.adduser( ply, target, "minge")
local mingeuser = ulx.command( CATEGORY_NAME, "ulx minge", ulx.mingeuser, "!minge" )
mingeuser:help("Turns a user into a minge." )
EDIT:  Tested - Works fine.
« Last Edit: June 17, 2011, 10:38:36 am by Aaron113 »
