Author Topic: Can't Disable Noclip  (Read 42960 times)
Offline theduce11
« on: July 11, 2011, 05:00:54 pm »
On my server, which is using DarkRP and ULX, sbox_noclip is set to 0, and nobody is allowed to use ulx noclip, but anyone higher than the user group can still press v to noclip. How can I stop this?
Re: Can't Disable Noclip
« Reply #1 on: July 11, 2011, 05:57:26 pm »
Pretty sure since noclipping is a Source server feature, not Gmod Sandbox (sbox), you'd use sv_noclip
Been a while though. I might be wrong.
Offline theduce11
« Reply #2 on: July 11, 2011, 06:29:14 pm »
There is no setting called sv_noclip.
« Reply #3 on: July 11, 2011, 07:52:09 pm »
Just checked my /cfg/server.cfg - last updated in February of 2010.
   "sbox_noclip"         "1"
If that doesn't work, then Garry's changed it, or another mod you have is breaking it, or conflicting with another mod that adjusts it.
Offline theduce11
« Reply #4 on: July 11, 2011, 09:03:06 pm »
I tried setting it to 1 and 0, but it still allows it. I only have WireMod installed right now. I guess it could be DarkRP.
« Reply #5 on: July 11, 2011, 09:13:02 pm »
Make sure you don't have it twice somewhere
Like, starting it with command line, but it execs in server.cfg
Or, you have it in one config, but another gets executed (autoexec.cfg)
Etc.
