Author Topic: Rank Tags  (Read 10650 times)
Offline Marmaduke
Rank Tags
« on: August 04, 2011, 09:09:55 am »
Is it possible to make it so when players of different ranks use chat or voice communication it will show the players rank before their name in a different colour and brackets? Because at the moment it is possible to put (superadmin) before your name but everyone can do it, and you will have to change your name when you goto a server you dont administrate. Evolve has this feature but ULX is better, and i want to stick with it?
Re: Rank Tags
« Reply #1 on: August 04, 2011, 09:50:32 am »
Offline Marmaduke
Re: Rank Tags
« Reply #2 on: August 04, 2011, 10:08:58 am »
i Mean how your name appears in chat
Re: Rank Tags
« Reply #3 on: August 04, 2011, 10:42:53 am »
Oops!  I swear I seen on here, but I guess it was on garrysmod.org.   :-[
Offline Marmaduke
Re: Rank Tags
« Reply #4 on: August 04, 2011, 11:04:51 am »
So does anyone know a way of doing it or a plugin of some sort?
Re: Rank Tags
« Reply #5 on: August 04, 2011, 11:10:35 am »
This is what I was refering to:  http://www.garrysmod.org/downloads/?a=view&id=78835
There is no plugin specifically made for ULX I believe, but maybe an idea for someone else to make it.
Re: Rank Tags
« Reply #6 on: August 04, 2011, 11:50:54 am »
I believe UTeam colors the name in chat to the team color (so you can identify superadmins/admins), but it doesn't insert a tag before the name.
Offline Willdy
Re: Rank Tags
« Reply #7 on: September 10, 2011, 03:08:41 am »
Sorry for the gravedig.
/index.php/topic,5391.0.html
local function lOnPlayerChat( ply, strText, bTeamOnly, bPlayerIsDead )
    local tab = {}
    local lTeam = 0
    if( IsValid( ply ) ) then
        lTeam = ply:Team()
    table.insert( tab, Color( team.GetColor( lTeam ) ) )
    table.insert( tab, "[" .. team.GetName( lTeam ) .. "] " )
    if ( bPlayerIsDead ) then
        table.insert( tab, Color( 255, 30, 40 ) )
        table.insert( tab, "*DEAD* " )
